Main Gear Spring Design
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List
Harvey Plummer
PostPosted: Tue Nov 28, 2017 8:35 am    Post subject: Main Gear Spring Design Reply with quote
Is anyone flying with the van der Voort designed shock absorber design for
the maing gear. It looks like a good replacement for the BHP shock cord design. One concern that I have though is the clearance between the 1" OD tube and 3/4" OD tube. There is about .060" clearance between the tubes. Seems a little excessive. Anyone with experience with this?
- The Matronics Pietenpol-List Email Forum -
http://www.matronics.com/Navigator?Pietenpol-List
spring gear.pdf
 Filename:  spring gear.pdf
 Filesize:  17.16 KB
 Downloaded:  252 Time(s)
Harv, 485PB
jarheadpilot82
PostPosted: Tue Nov 28, 2017 5:24 pm    Post subject: Re: Main Gear Spring Design Reply with quote
Here is another option. This is what I have on my Piet project.
https://flycorvair.net/2012/10/27/new-die-spring-landing-gear-on-a-pietenpol-10-a-m-4-p-m/
If you are interested, I can send you the link where I purchased my die springs. $40.00 or so each, as I recall. Much less than Wag Aero or Wicks or ACS.
Semper Fi,
Terry Hand
Athens, GA
vk3eka(at)bigpond.net.au
PostPosted: Tue Nov 28, 2017 7:06 pm    Post subject: Main Gear Spring Design Reply with quote
Hi Guys,
I have just built one for my Wagabond Project.
Simple to build and looks good and strong.
Peter
Wonthaggi Australia
Get Outlook for iOS
On Wed, Nov 29, 2017 at 12:24 PM +1100, "jarheadpilot82" <jarheadpilot82(at)hotmail.com (jarheadpilot82(at)hotmail.com)> wrote:
--> Pietenpol-List message posted by: "jarheadpilot82"
Semper Fi,
Terry Hand
Athens, GA
http://forums.matronics.com/viewtopic.php?p=475834#475834
steven.d.dortch(at)gmail.
PostPosted: Tue Nov 28, 2017 7:17 pm    Post subject: Main Gear Spring Design Reply with quote
I did this and really liked the looks. I have yet to finish my plane.
BTW right now my concentration is on getting my commercial ticket next Wednesday.
Blue skies,
Steve D
On Nov 28, 2017 7:25 PM, "jarheadpilot82" <jarheadpilot82(at)hotmail.com (jarheadpilot82(at)hotmail.com)> wrote:
--> Pietenpol-List message posted by: "jarheadpilot82" <jarheadpilot82(at)hotmail.com (jarheadpilot82(at)hotmail.com)>
Semper Fi,
Terry Hand
Athens, GA
br> enpol-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List
WIKI -
Harvey Plummer
PostPosted: Wed Nov 29, 2017 11:21 am    Post subject: Re: Main Gear Spring Design Reply with quote
So which did you guys build? what Jarhead is suggesting or the van der Voort design I referred to?
Thanks.
Harv, 485PB
PostPosted: Wed Nov 29, 2017 12:46 pm    Post subject: Main Gear Spring Design Reply with quote
The same as the construction on WW’s site.
Cheers
Peter
Get Outlook for iOS
On Thu, Nov 30, 2017 at 6:21 AM +1100, "Harvey Plummer" <plummerharvey(at)yahoo.com (plummerharvey(at)yahoo.com)> wrote:
--> Pietenpol-List message posted by: "Harvey Plummer"
Thanks.
Harv, 485PB
http://forums.matronics.com/viewtopic.php?p=475933#475933
PostPosted: Wed Nov 29, 2017 5:48 pm    Post subject: Main Gear Spring Design Reply with quote
Drawing of the can  Not drawn to any scale whatsoever.
On Nov 29, 2017 7:44 PM, "Steven Dortch" <steven.d.dortch(at)gmail.com (steven.d.dortch(at)gmail.com)> wrote:
Here are my drawings of the setup. NOTE Not drawn to any scale known to man.
On Nov 29, 2017 2:49 PM, <vk3eka(at)bigpond.net.au (vk3eka(at)bigpond.net.au)> wrote:
Cheers
Peter
Get Outlook for iOS
Thanks.
Harv, 485PB
 Filesize:  2.31 MB
 Viewed:  4273 Time(s)
PostPosted: Wed Nov 29, 2017 5:49 pm    Post subject: Main Gear Spring Design Reply with quote
Another drawing. The measurements are in furlongs, cubits and pecks.
On Nov 29, 2017 7:47 PM, "Steven Dortch" <steven.d.dortch(at)gmail.com (steven.d.dortch(at)gmail.com)> wrote:
Cheers
Peter
Get Outlook for iOS
Thanks.
Harv, 485PB
 Filesize:  2.37 MB
PostPosted: Wed Nov 29, 2017 5:50 pm    Post subject: Main Gear Spring Design Reply with quote
One more.
On Nov 29, 2017 7:49 PM, "Steven Dortch" <steven.d.dortch(at)gmail.com (steven.d.dortch(at)gmail.com)> wrote:
Cheers
Peter
Get Outlook for iOS
Thanks.
Harv, 485PB
 Filesize:  1.88 MB
kipgohio1957(at)gmail.com
PostPosted: Wed Nov 29, 2017 6:15 pm    Post subject: Main Gear Spring Design Reply with quote
Once finished, is the interior lubricated/greased/protected from corrosion in any way? Also, it would appear that the spring has to be shorter than the can, how do you determine by how much, or am I looking at it wrong? Overall, I like the idea much better than the other spring designs I’ve seen.
Kip Gardner
On Nov 29, 2017, at 8:47 PM, Steven Dortch <steven.d.dortch(at)gmail.com (steven.d.dortch(at)gmail.com)> wrote:
Cheers
Peter
Get Outlook for iOS
Thanks.
Harv, 485PB
<IMG_20171017_175521188.jpg>
PostPosted: Wed Nov 29, 2017 6:35 pm    Post subject: Main Gear Spring Design Reply with quote
Kip,
The spring is 6 inches long, I made the tube 6 1/4 inches to take into account the welded cap on the end. I added another spacer to the top of the cap to provide a bit more of a gap so that nothing was damaged when welding the top cap. The cap, spacer and weld are slightly thicker that the 1/4 inch so I compressed the spring very slightly when I welded on the top cap. A little bit of compression stops any rattles when no load is applied.
I painted the long tube before welding the top cap in place. I intend to squirt some oil in the rod end hole (top) every now and again (say every annual) to stop the corrosion.
Cheers
Peter
Wonthaggi Australia
http://www.cpc-world.com
From: <owner-pietenpol-list-server(at)matronics.com> on behalf of Kip Gardner <kipgohio1957(at)gmail.com>
Reply-To: <pietenpol-list(at)matronics.com>
Date: Thursday, 30 November 2017 at 1:14 pm
Subject: Re: Re: Main Gear Spring Design
Kip Gardner
On Nov 29, 2017, at 8:47 PM, Steven Dortch <steven.d.dortch(at)gmail.com> wrote:
On Nov 29, 2017 7:44 PM, "Steven Dortch" <steven.d.dortch(at)gmail.com> wrote:
PostPosted: Wed Nov 29, 2017 6:48 pm    Post subject: Main Gear Spring Design Reply with quote
Peter,
Thanks, that all makes perfect sense, even to me Smile !
Kip
On Nov 29, 2017, at 9:34 PM, Peter Johnson <vk3eka(at)bigpond.net.au (vk3eka(at)bigpond.net.au)> wrote:
Kip,
Cheers
Peter
Wonthaggi Australia
From: <owner-pietenpol-list-server(at)matronics.com (owner-pietenpol-list-server(at)matronics.com)> on behalf of Kip Gardner <kipgohio1957(at)gmail.com (kipgohio1957(at)gmail.com)>Reply-To: <pietenpol-list(at)matronics.com (pietenpol-list(at)matronics.com)>Date: Thursday, 30 November 2017 at 1:14 pmTo: <pietenpol-list(at)matronics.com (pietenpol-list(at)matronics.com)>Subject: Re: Re: Main Gear Spring Design
Kip Gardner
Cheers
Peter
Get Outlook for iOS
--> Pietenpol-List message posted by: "Harvey Plummer" So which did you guys build? what Jarhead is suggesting or the van der Voort design I referred to? Thanks. --------Harv, 485PB
<IMG_1015.jpg><IMG_1016.jpg>
PostPosted: Wed Nov 29, 2017 8:24 pm    Post subject: Main Gear Spring Design Reply with quote
The spring is under compression. When we welded one, either a drop of slag
got in the way or there was a tiny weld to the spring. No movement. I fixed
it by chaining it between two truck bumpers and giving it a jerk. It worked
echobravo4
PostPosted: Mon Dec 04, 2017 3:59 pm    Post subject: Re: Main Gear Spring Design Reply with quote
the link Terry supplied does have all the measurements and details of the construction...
Earl Brown
I may not have gone where I intended to go, but I think I have ended up where I intended to be.
Tr8nicz
PostPosted: Thu Aug 02, 2018 9:18 pm    Post subject: Re: Main Gear Spring Design Reply with quote
Isn't it complicated when you chained it between the two truck bumpers? I'm quite unsure if other parts will be damaged.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List All times are GMT - 8 Hours
