Wiring an Engine Monitor with dual electrical systems.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List
n320wt(at)yahoo.com
PostPosted: Thu Dec 07, 2017 4:58 am    Post subject: Wiring an Engine Monitor with dual electrical systems. Reply with quote
Jacob, This configuration will not work. DC current does not flow through a capacitor once the capacitor reaches system voltage. It acts like a switch that turns off. You might want to check with aeroelectric list for best advice. A capacitor in parallel instead of in series might work but other components would be necessary.
BRIAN ALLEY (N320WT) CARBON FIBER COMPOSITES Hangar #17, Ona Airpark Ona, WV 25545 www.carbonfiberwv.com 304-395-4932 cell
On Wednesday, December 6, 2017, 12:48:21 PM EST, Jacob Apple <jbapple(at)ncsu.edu> wrote:
--> Glasair-List message posted by: Jacob Apple <jbapple(at)ncsu.edu (jbapple(at)ncsu.edu)>
Hi everyone,
I have a GlaStar with with an aerosance fadec that went bad. To get flying again I am pulling the fadec (which covers both fuel injection and ignition) out, as well as the VM1000 engine monitor because it only works with the fadec. The new engine monitor only has a main power in, and uses that to determine system voltage.
From my old setup, I have 2 switches on the dash that switch voltage and amperage displays from system 1 to system 2. I am trying to figure out how to make use of these with my new engine monitor.
Is it crazy to think I could have a SPDT (on-on) switch with 2 battery in’s (the 2 load positions) and 1 output that flows through a capacitor then into the engine monitor to switch voltages? I realize that switch is made for 1 battery in and 2 load outs, can I run it backwards? In my mind, the capacitor would have enough stored energy to keep the engine monitor running during the system 1/2 switch.
I’m a newb with electricity so be gentle Smile
_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
http://www.matronics.com/Navigator?Glasair-List
http://forums.matronics.com
_-= --> http://www.matronics.==
- The Matronics Glasair-List Email Forum -
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List All times are GMT - 8 Hours
