Rear floor pans
kearney
PostPosted: Sun Dec 10, 2017 2:36 pm    Post subject: Rear floor pans Reply with quote
Hi
I insulated under my front floor pans using fire break foam. I am considering doing the same think under the rear floor pans for insulation / sound proofing purposes.
I am wondering what others have done in this spot. Is there any real benefit to insulating / soundproofing here?
Inquiring minds need to know.
Les
Kelly McMullen
PostPosted: Sun Dec 10, 2017 5:48 pm    Post subject: Rear floor pans Reply with quote
No measured benefit, but I did it because I had the foam.
-sent from the I-droid implanted in my forearm
On Sun, Dec 10, 2017 at 3:36 PM, kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
--> RV10-List message posted by: "kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)>
Hi
Les
http://forums.matronics.com/viewtopic.php?p=476321#476321
WIKI -
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Gordon Anderson
PostPosted: Mon Dec 11, 2017 11:55 am    Post subject: Re: Rear floor pans Reply with quote
Hi Les, Kelly, it has been suggested that using foam under the front floor pans can help reduce external noise caused by exhaust resonating on the underside of the fuselage. I bet no-one has done a before/after test to prove it though Smile
Good choice to use fireproof foam - do you have specifics?
Gordon
41015 Switzerland
Kelly McMullen
PostPosted: Mon Dec 11, 2017 1:19 pm    Post subject: Rear floor pans Reply with quote
I don't believe there is such a thing as fireproof foam. All the test results I have seen of material designed for the firewall have failed the official FAA test, 2000 degrees for a time I don't remember. Either smoke, fall apart or transfer too much heat.I don't think you need any better than what is needed for interior not against the firewall. Aircraft Spruce sells such a foam, although it doesn't pass with adhesive backing, you can get it without the adhesive, which isn't needed for the floor. The exhaust pipes are angled down and most of the exhaust stays off the bottom of fuselage.
On Mon, Dec 11, 2017 at 12:55 PM, Gordon Anderson <mregoan(at)hispeed.ch (mregoan(at)hispeed.ch)> wrote:
--> RV10-List message posted by: "Gordon Anderson" <mregoan(at)hispeed.ch (mregoan(at)hispeed.ch)>
Gordon
41015 Switzerland
http://forums.matronics.com/viewtopic.php?p=476344#476344
WIKI -
Kelly McMullen
KCHD
kearney
PostPosted: Mon Dec 11, 2017 8:51 pm    Post subject: Re: Rear floor pans Reply with quote
Hi Gordon
I used Abesco FP200 fire rated foam.
Cheers
Les
johngoodman
PostPosted: Tue Dec 12, 2017 5:11 am    Post subject: Re: Rear floor pans Reply with quote
kearney wrote:
Hi Gordon
Cheers
Les
So did I....
John
Albert Gardner
PostPosted: Tue Dec 12, 2017 8:04 am    Post subject: Rear floor pans Reply with quote
I wish the oil would also!
Albert Gardner
N991RV
Yuma, AZ
RV-9A N872RV
RV-10 N991RV
Kelly McMullen
PostPosted: Tue Dec 12, 2017 5:56 pm    Post subject: Rear floor pans Reply with quote
It will if you keep it on the inside of the engine. 8^)Do Not Archive
On Tue, Dec 12, 2017 at 9:04 AM, Albert <ibspud(at)roadrunner.com (ibspud(at)roadrunner.com)> wrote:
Albert Gardner
N991RV
Yuma, AZ
Kelly McMullen
KCHD
