LAA Airworthiness Alert. AIL December 2017 All Europas
budyerly(at)msn.com
PostPosted: Fri Dec 15, 2017 1:30 pm    Post subject: LAA Airworthiness Alert. AIL December 2017 All Europas Reply with quote
David and all,
Over here in the States we weld up a 57 degree elbow out of 2" .049 6061T-6. Cut to fit. 2" fuel hose pieces and done.
Rather than those beautiful bent tubes, would the LAA allow such a simple mod that only costs a few bucks to make? The certified welder is the only cost. I cut the tube on my compound miter saw.
Curt welds it up in 10 minutes. It takes 5 minutes to trim up the ends to fit.
Best Regards,
Bud Yerly,
Custom Flight Creations, Inc.
Sent from my Verizon Wireless 4G LTE DROID
On Dec 15, 2017 4:20 PM, davidjoyce(at)doctors.org.uk wrote:
Anthony, It would be interested to know whether you usually fill the fuel system (and if so ? up to the top) before you put the plane away or whether you fill up just before you go flying. That is will that pipe have spent most of its life in contact with fuel or with fumes? Regards, David Joyce, GXSDJ
On 2017-12-15 20:47, anthony van eldik wrote:
Dear David,
For your information my fuel filler hose dated 2001 was inspected independently by two engineers including my inspector and found to be in very good condition inside/out.Fuel used over the years was BP premium unleaded  .Pending a suitable replacement the hose will be refitted. It should be possible to find a replacement silicone fuel approved hose. I have the Xs extended baggage bay short hose version.
Anthony van Eldik
On 15 Dec 2017, at 20:17, davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk) wrote:
Yes 51 mm it is, but if there is no rush, there is a good possibility of the LAA coming up with an approved solution fairly soon
Regards, David Joyce,GXSDJ
On 2017-12-15 19:54, Roland wrote:
--> Europa-List message posted by: "Roland" <schmidtroland(at)web.de (schmidtroland(at)web.de)>
Is 51 mm inner diameter the correct size?
I'm about to replace the fuel hoses next month and I'm afraid that the fuel filler hose has deteriorated on the inside as well and I'd like to choose the best available.
Roland
PH-ZTI
XS TG 914
http://forums.matronics.com/viewtopic.php?p=476416#476416
ttp://www.matronics.com/Navigator?Europa-List
ics.com
.com
.matronics.com/contribution
afc.tulips7(at)gmail.com
PostPosted: Sun Dec 17, 2017 2:44 am    Post subject: LAA Airworthiness Alert. AIL December 2017 All Europas Reply with quote
On 16 Dec 2017, at 11:19, GRAHAM SINGLETON <grahamsingleton(at)btinternet.com (grahamsingleton(at)btinternet.com)> wrote:
[quote]Best solution is to use short silicone joints to an aluminium elbow, it's much lighter and the silicone is less problematic regarding erosion etc.
Tim Ward organised a batch of nice elbows but that was years ago.
It wouldn't be difficult to weld one up?
Graham
On Saturday, 16 December 2017, 9:33, Brian Davies <brian.davies44(at)gmail.com (brian.davies44(at)gmail.com)> wrote:
--> Europa-List message posted by: "Brian Davies" <brian.davies44(at)gmail.com (brian.davies44(at)gmail.com)>
Demon Tweeks says in stock 3 day delivery.
Brian
PostPosted: Sun Dec 17, 2017 2:46 am    Post subject: LAA Airworthiness Alert. AIL December 2017 All Europas Reply with quote
On 17 Dec 2017, at 10:43, anthony van eldik <afc.tulips7(at)gmail.com (afc.tulips7(at)gmail.com)> wrote:
Graham
Brian
PostPosted: Sun Dec 17, 2017 2:53 am    Post subject: LAA Airworthiness Alert. AIL December 2017 All Europas Reply with quote
Dear Graham,I fully agree with you this would be the best solution. Silicon fuel resistant hose in 51 size is readily available and it should be possible to obtain aluminium 60 degrees elbows like Tim Ward had many years ago.
Anthony Van Eldik
Graham
--> Europa-List message posted by: "Brian Davies" <brian.davies44(at)gma (brian.davies44(at)gmail.com)brian.davies44(at)gmail.com (brian.davies44(at)gmail.com)il.com (brian.davies44(at)gmail.com)>
Brian
