jbdarke(at)gmail.com Guest
Posted: Wed Dec 13, 2017 4:56 am Post subject: Mark III transport |
Any ideas on how to load a Mark III Xtra into a 26 foot moving truck.
John Darke, 72 Sabal Drive - Punta Gorda, FL 33950 - 941-676-0429
herbgh(at)nctc.com Guest
Posted: Wed Dec 13, 2017 5:45 am Post subject: Mark III transport |
Lot easier if the truck is sitting still....
I would go nose first...secure the main gear to the floor with straps that go under 2X2's that are screwed to the floor in front and at the rear of the wheels..
I would elevate the tail boom a bit in front of the horiz stab....on a pedestal that is screwed to the floor... maybe 5 or 6 inches wide and cushioned with thick foam or couch cushion.. Strap that ....
Drop the wings to the floor on Couch cushions leaving them attached at the rear spar.... secure the wings with some long straps..
Herb
On 12/13/2017 06:56 AM, John Darke wrote:
| Quote: | Any ideas on how to load a Mark III Xtra into a 26 foot moving truck.
brubakermal(at)yahoo.com Guest
Posted: Wed Dec 13, 2017 6:11 am Post subject: Mark III transport |
the wings want to drag on the ground if you run them up a ramp that is too steep, I like to put the tail under a 5 gallon bucket and always use pipe insulation around the tail and ailerons . also saran packing wrap helps hold thing together without chaffing .and never store things inside the fuselage that can shift and poke holes in the fabric.
Malcolm & Jeanne Brubaker
Michigan Sport Pilot Repair
http://michigansportpilotrepair.com
LSRM-A, PPC, WS
Great Sails - Sailmaker
for Ultralight & Light Sport
(989)513-3022
Sent: Wednesday, December 13, 2017 8:49 AM
Subject: Re: Kolb-List: Mark III transport
Herb
-- John Darke, 72 Sabal Drive - Punta Gorda, FL 33950 - 941-676-0429
russk50(at)gmail.com Guest
Posted: Wed Dec 13, 2017 7:11 am Post subject: Mark III transport |
FWIW - I hang the wings on the walls. tailwheel rides in a track between 2 2x2’s screwed to the floor.Electric winch hauls Xtra into trailer. Strap down mains, put boom tube non a strong suppport & lash down. Struts, center section hang on walls too | Quote: | On Dec 13, 2017, at 7:56 AM, John Darke <jbdarke(at)gmail.com (jbdarke(at)gmail.com)> wrote:
Posted: Wed Dec 13, 2017 9:15 am Post subject: Mark III transport |
Thanks for that Herb and Russ. I assume ramps would be need to lift it into the truck (or a couple of weight lifters)?
On Wed, Dec 13, 2017 at 8:45 AM, SugarDad <herbgh(at)nctc.com (herbgh(at)nctc.com)> wrote:
Herb
John Darke, 72 Sabal Drive - Punta Gorda, FL 33950 - [url=tel:(941)%20676-0429]941-676-0429[/url]
Posted: Wed Dec 13, 2017 9:28 am Post subject: Mark III transport |
Yep!! Ramps are good...the problem, is with dragging the wings and tail boom...as the plane moves forward...Being able to back the truck into a berm...is much mo' better...Herb
On 12/13/2017 11:15 AM, John Darke wrote:
| Quote: | Thanks for that Herb and Russ. I assume ramps would be need to lift it into the truck (or a couple of weight lifters)?
Herb
John Darke, 72 Sabal Drive - Punta Gorda, FL 33950 - [url=tel:%28941%29%20676-0429]941-676-0429[/url]
Posted: Wed Dec 13, 2017 10:14 am Post subject: Mark III transport |
Yes sir makes sense. Got an idea on how to get some dual time in a Mark III?
On Wed, Dec 13, 2017 at 12:27 PM, SugarDad <herbgh(at)nctc.com (herbgh(at)nctc.com)> wrote:
Herb
neilsenrm(at)gmail.com Guest
Posted: Thu Dec 14, 2017 10:15 am Post subject: Mark III transport |
Dual time is good especially if you’re a GA pilot.
Those big trucks can give your mklll a rough ride and worst in the back. Be sure to support the wings where they attach to the universal joints.
Rick Neilsen
Redrive VW MKlll
On Wed, Dec 13, 2017 at 11:17 AM John Darke <jbdarke(at)gmail.com (jbdarke(at)gmail.com)> wrote:
| Quote: | Yes sir makes sense. Got an idea on how to get some dual time in a Mark III?
Herb
capedavis(at)yahoo.com Guest
Posted: Sat Dec 16, 2017 8:30 am Post subject: Mark III transport |
Wouldn’t it be better to hang the wings on the wall I a couple pieces of carpet ?
On Dec 13, 2017, at 8:45 AM, SugarDad <herbgh(at)nctc.com (herbgh(at)nctc.com)> wrote:
Herb
