willydewey
Joined: 24 Sep 2014 Posts: 53 Location: Guildford Surrey United Kingdom
Posted: Tue Jan 09, 2018 4:35 am Post subject: Fuel Inlet Pipe repacement on 914 XS |
I am considering replacement of the rubber connector from the tank to the cobra fitting.. Engineering suggest that the existing rubber pipe requires inspection before the next flight.
My anxiety is squeezing or removing this item will destroy it in any event hence the need to order an aluminium tube and connecting rubbers ASAP
I gather someone is taking orders for the tube for delivery from NZ and the rubbers are from Tim Ward. I would like to be included in these bulk orders.
willydewey(at)gmail.com
Bill Dewey G-IANI
_________________ Give a wise man knowledge and he will be yet wiser |
ward.t(at)xtra.co.nz Guest
Posted: Tue Jan 09, 2018 4:02 pm Post subject: Fuel Inlet Pipe repacement on 914 XS |
Hi Bill,
The aluminium elbow I distribute is for the XS both Monowheel and Tri Gear. It also can be used for the Monowheel Classic which has incorporated the Baggage Mod and MTOW increase. It connects with the white plastic cobra from the fuel inlet, supplied by the XS Kit, replacing the rubber elbow, to the tank inlet.
I can put you on the list. Once a UKLAA Mod. approval is reached and the cost is of production is agreed upon, then I shall let you know.
Tim
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Mob +64 210640221
| Quote: | On 9/01/2018, at 4:35 AM, willydewey <willydewey(at)gmail.com> wrote:
Bill Dewey G-IANI
http://forums.matronics.com/viewtopic.php?p=477195#477195
willydewey
Posted: Wed Jan 17, 2018 6:10 am Post subject: Re: Fuel Inlet Pipe repacement on 914 XS |
Hi Tim
thanks for the reply.I think its best I wait for the LAA to finalise the MOD and then I will take some action
I prefere to wait and see
Bill GIANI
