Pietenpol-List Digest: 3 Msgs - 01/19/18
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List
oldbird
PostPosted: Sat Jan 20, 2018 10:29 am    Post subject: Pietenpol-List Digest: 3 Msgs - 01/19/18 Reply with quote
Hi Rick
Please take the angles into account while calculating loads on wires in between the lift struts.​ My struts are carbon fiber reinforced plywood+wood and I used 2200 lb turnbuckles, hoping my calc is correct.
Semih Oksay
Istanbul - Turkey
On Sat, Jan 20, 2018 at 10:40 AM, Pietenpol-List Digest Server <pietenpol-list(at)matronics.com (pietenpol-list(at)matronics.com)> wrote:
Today's complete Pietenpol-List Digest can also be found in either of the
two Web Links listed below.  The .html file includes the Digest formatted
and Message Navigation.  The .txt file includes the plain ASCII version
of the Pietenpol-List Digest and can be viewed with a generic text editor
HTML Version:
    http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2018-01-19&Archive=Pietenpol
Text Version:
    http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2018-01-19&Archive=Pietenpol
                           Pietenpol-List Digest Archive
                     Total Messages Posted Fri 01/19/18: 3
Today's Message Index:
     1. 11:20 AM - Re: Corrosion Treating the Inside of the Cabanes and Diagonals  (at7000ft)
     2. 09:52 PM - Re: Corrosion Treating the Inside of the Cabanes and Diagonals  (Elizabeth Cooper)
     3. 10:08 PM - Re: Corrosion Treating the Inside of the Cabanes and Diagonals  (jarheadpilot82)
________________________________  Message 1  _____________________________________
Time: 11:20:34 AM PST US
Subject: Re: Corrosion Treating the Inside of the Cabanes and Diagonals
From: "at7000ft" <at7000ft(at)gmail.com (at7000ft(at)gmail.com)>
Beautiful work on your welded fuselage Terry. Concerning the flying struts, one
thing that makes me feel better when flying mine and pulling a few Gs is the
old Pietenpol fable (which may be true) that Bernard said that he designed the
Piet so the flying wires between the struts will fully support the wings in flight
even if all four struts fall off. And its not that hard to believe since
at a 1100 lb gross weight each of the four cables would only have to support
275 lbs. Redundancy you don't get with a Cub or most other high wing with flying
strut designs.
Rick Holland
Rick Holland
NX6819Z
http://forums.matronics.com/viewtopic.php?p=477456#477456
________________________________  Message 2  _____________________________________
Time: 09:52:44 PM PST US
From: Elizabeth Cooper <eacooper9(at)yahoo.com (eacooper9(at)yahoo.com)>
Diagonals
On Wed, 1/17/18, jarheadpilot82 <jarheadpilot82(at)hotmail.com (jarheadpilot82(at)hotmail.com)> wrote:
 Subject: Corrosion Treating the Inside of the Cabanes and Diagonals
 To: pietenpol-list(at)matronics.com (pietenpol-list(at)matronics.com)
 Date: Wednesday, January 17, 2018, 9:42 AM
 "jarheadpilot82" <jarheadpilot82(at)hotmail.com (jarheadpilot82(at)hotmail.com)>
 I have built my cabanes and diagonals,
 and I choses to use 4130 Chromoly streamlined tubing as
 opposed to aluminum or wood. I want to corrosion treat the
 inside of the cabanes and am looking for suggestions. Steve
 D, I know you mentioned using CorrosionX on your Bonanza.
 Which version? How would you apply to the inside of the
 tubes?
 Thanks in advance for the suggestions.
 Semper Fi,
 Terry Hand
 Athens, GA
Hi Terry,  Linseed oil absorbs water.  The whole reason behind boiled linseed oil
is that it drives out the moisture, so you have only pure oil.  Unfortunately,
once you have opened the can, it begins the absorption process all over again.
As it is stored, it collects more and more moisture.  If you intend to reuse
what you returned to the container it should be boiled once again to remove
that water.  Beautiful job on the welding.  Keep up the good work.  Be good,
R. Scott Bartko  Low and slow with the top down
________________________________  Message 3  _____________________________________
Time: 10:08:28 PM PST US
From: "jarheadpilot82" <jarheadpilot82(at)hotmail.com (jarheadpilot82(at)hotmail.com)>
Rick,
I would love to take credit for the beautiful welds, and they are beautiful. However,
my welding skills are extremely puny, so I found a great welder in town.
David owns a custom bicycle business. I figured that, since he uses 4130 chromoly
on many
 of his bike frames and he tig welds, he would be a good source, and he has actually
been a great one.
If any of you out there are looking for a welder, you might try going the same
route I did. See if there is a custom bicycle shop or similar in your town. It
worked for me.
Semper Fi,
Terry Hand
Athens, GA
http://forums.matronics.com/viewtopic.php?p=477463#477463
br> enpol-List" target="_blank" rel="noreferrer">http://www.matronics.com/Navigator?Pietenpol-List
_blank" rel="noreferrer">http://forums.matronics.com
WIKI -
lank" rel="noreferrer">http://wiki.matronics.com
target="_blank" rel="noreferrer">http://www.matronics.com/contribution
Semih Oksay
- The Matronics Pietenpol-List Email Forum -
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List All times are GMT - 8 Hours
