kenryan
Posted: Mon Jan 22, 2018 9:22 am Post subject: fuel pressure sensor |
I have a fuel pressure sender -- UMAÂ N1EU07D -- for my Rotax 914. It is a differential sensor that senses fuel pressure and airbox pressure, and reports the difference.
The wiring that comes with the sensor is a 3 wire shielded pigtail that is about a foot long. The 3 wires are 12v power, ground and signal.
To connect this to my Dynon Skyview EMS module I will need to strip it back a few inches in order to accommodate a 37 pin plug, leaving about 8 inches of shielded bundle running from the sensor housing to the 37 pin plug. None of the wires on the pre-made Dynon harness are shielded. The Dynon manual makes no mention of utilizing the shield.
The shielded wire would only be about 8 inches long, or less, from the sensor to the 37 pin plug. The remainder of the run (approximately 18 inches) is unshielded.
I cannot see any reason to utilize the shield that comes with the sensor. Am I correct?
Ken
Posted: Mon Jan 22, 2018 9:37 am Post subject: fuel pressure sensor |
At 11:21 AM 1/22/2018, you wrote:
Quote: | I have a fuel pressure sender -- UMAÂ N1EU07D -- for my Rotax 914. It is a differential sensor that senses fuel pressure and airbox pressure, and reports the difference.
I cannot see any reason to utilize the shield that comes with the sensor. Am I correct? |
No reason to think otherwise . . . these
signals are generally not vulnerable to
electrostatically coupled antagonists . . .
further, it's unlikely that any such antagonists
will be found sharing the wire bundles.
I think you can move ahead . . .
ashleysc(at)broadstripe.n Guest
Posted: Mon Jan 22, 2018 10:19 am Post subject: fuel pressure sensor |
HiKen;
HiAll;
I am going to go way out on a limb here: I have a different fuel pressure sender, that is not shielded, provided by Swift that also makes gauges. There is a possibility that your manufacturer only used shielded wire because of its durability. Presuming that you have already tried to talk with the manufacturer and gotten no joy, I would try it without shielding the remainder of the run and see what happens. If that fails, you can buy shielding in flattened tubes that can be put over the unshielded bundle, connected to the sensor shield and grounded at the far end. I have some extra 3/8" ID if you want to give it a try; no charge.
Cheers! Stu.
Sent: Monday, January 22, 2018 9:21:24 AM
Subject: fuel pressure sensor
I have a fuel pressure sender -- UMA N1EU07D -- for my Rotax 914. It is a differential sensor that senses fuel pressure and airbox pressure, and reports the difference.
Ken
kenryan
Posted: Mon Jan 22, 2018 11:56 am Post subject: fuel pressure sensor |
Thanks everybody.
On Mon, Jan 22, 2018 at 8:39 AM, <ashleysc(at)broadstripe.net (ashleysc(at)broadstripe.net)> wrote:
Quote: | HiKen;
HiAll;
Cheers!  Stu.
From: "Ken Ryan" <keninalaska(at)gmail.com (keninalaska(at)gmail.com)>
Subject: AeroElectric-List: fuel pressure sensor
Ken
