alan.twigg775(at)gmail.co Guest
Posted: Wed Jan 31, 2018 4:59 am Post subject: Fwd: Motorglider Airbrakes |
Begin forwarded message:
| Quote: | From: Alan Twigg <alan.twigg(at)bicestergliding.com (alan.twigg(at)bicestergliding.com)>
Date: 31 January 2018 at 12:57:37 GMT
To: Alan Twigg <alan.twigg775(at)gmail.com (alan.twigg775(at)gmail.com)>
Subject: Fwd: Motorglider Airbrakes
| Quote: | From: alan.twigg(at)bicestergliding.com (alan.twigg(at)bicestergliding.com)
Date: 31 January 2018 at 12:17:10 GMT
To: Europa list <europa-list(at)matronics.com (europa-list(at)matronics.com)>
Subject: Motorglider Airbrakes
I am impressed with the write up provided by Bud, on airbrake fitting that was omitted from the factory build manual, I feel however that I have existed in a void over here in the UK.
The information is great but mentions a phenolic guide in the wing root. This was not included in my kit, can anyone give me measurements or better still a drawing.
I was alarmed to read that I should have fitted the wing-root fairings after fitting the airbrake inner fittings; too late, my fairings are on and painted. I guess I can work around this.
Alan Twigg
h&jeuropa
Posted: Thu Feb 01, 2018 7:28 am Post subject: Re: Fwd: Motorglider Airbrakes |
Alan,
The bearing you are missing is part number GAB03. Perhaps Europa have some.
I've attached a sketch with dimensions if you have to have them made. The material is the same Tuffnol used in the cockpit module.
I hope this helps.
Jim Butcher
N241BW
| Description: |
 Download |
| Filename: |
GAB02 AB Bearing.pdf |
| Filesize: |
290.95 KB |
| Downloaded: |
402 Time(s) |
