Desser tires
flyayak
PostPosted: Mon Jan 29, 2018 2:34 am    Post subject: Desser tires Reply with quote
Hi all,
I didn´t write anything for a long time, but I am still a huge fan of this forum.
I recently purchased a set of Desser tires for my Yak 52 and realized, that the tube doesn´t fit because the valve stem (before the 90 degree bent) is too short.
If I get the rubber stem guard reworked (reduce width), it will be possible to use the tubes.
Also the pressure of the nose wheel is limited to 30 psi, which is much more less than the manual stated. Seems to be because of the different structure of this tires, right?
Any thought from those, who use Desser tires as well?
Thanks a lot in advance.
Best regards
Stefan
