IO-540 alternator-starter bracket
whodja
PostPosted: Tue Jan 30, 2018 4:13 am    Post subject: IO-540 alternator-starter bracket Reply with quote
Does anyone know who sells the bracket for a boss mount from alternator
to starter bracket? I have a B and C alternator and OEM Lycoming/Skytec starter.
LarryRosen
PostPosted: Tue Jan 30, 2018 6:54 am    Post subject: IO-540 alternator-starter bracket Reply with quote
Did you try B&C?
Get Outlook for iOS
From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com> on behalf of whodja <whodja(at)gmail.com>
Sent: Tuesday, January 30, 2018 7:13:19 AM
Subject: IO-540 alternator-starter bracket
--> RV10-List message posted by: "whodja" <whodja(at)gmail.com>
http://forums.matronics.com/viewtopic.php?p=477689#477689
Email Forum -
-List">http://www.matronics.com/Navigator?RV10-List
p; - MATRONICS WEB FORUMS -
ums.matronics.com
matronics.com
p; -Matt Dralle, List Admin.
Larry Rosen
#40356
N205EN (reserved)
<http>
tshort
PostPosted: Wed Jan 31, 2018 12:00 am    Post subject: Re: IO-540 alternator-starter bracket Reply with quote
So far as I know no one makes one.
I have a plane power 60A alternator and a B&C starter.
The install instructions for the starter state that no bracket is needed if a B&C alternator (or any alternator that is perfectly balanced) is installed. [My summary, I don't have the instructions in front of me]
I'm still in the process of installing things, but am seriously considering not installing a bracket. I called B&C, and was told that the bracket would provide extra support / vibration dampening and might extend the life of the PP alternator.
Seeing as how it's not installed with the B&C alt/starter combo, I may just go without...
Edit ....
I just reread your post. Looks like you have the opposite combo as I do. I might call B&C (or check the install manual) - the bracket may not be necessary based on the install instructions I have for the starter. I don't see that bracket called out in the wide deck install instructions for the B&C alternator.
Kelly McMullen
PostPosted: Wed Jan 31, 2018 5:31 am    Post subject: IO-540 alternator-starter bracket Reply with quote
Have you talked to Plane Power? This is what is normally in their experimental kit:
http://planepower.aero/images/AL12-EI60-B.jpg
They offer both case mount and boss mount kits with all brackets. Is the bracket you need of differing dimensions than a stock
alternator and starter combo? I used the stock PP kit with a Kelly (now Hartzell) EZ Drive starter with no problem.
Sent from my IBM-360 main frame
On Tue, Jan 30, 2018 at 5:13 AM, whodja <whodja(at)gmail.com (whodja(at)gmail.com)> wrote:
--> RV10-List message posted by: "whodja" <whodja(at)gmail.com (whodja(at)gmail.com)>
WIKI -
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
