V.G. update
Rex Rodebush
PostPosted: Tue Feb 06, 2018 3:25 pm    Post subject: V.G. update Reply with quote
Things are a little slow so I thought I would update my experience with v.g.'s
I added the Stolspeed v.g.'s on my Xtra (912 100 HP with Warp Drive 3-blade prop) last September. Placement per Stolspeed's recomendation except that I used the 60mm spacing from O.B to I.B. of the wing. Also centered the pair of V.G.'s in each valley between the ribs. I also added v.g.'s to the underside of the horizontal stabilizer.
The stall speed went from 40 indicated to 32 indicated and about 30 indicated with 20 degrees of flaps. I have 14 landings with the v.g.'s and they have been the best by far. It seems I have much more time to get the plane down to just a few inches above the runway than before. It also seems the pitch control is much more stable. Before I was always overcontroling up and down after the round out. That hasn't happened with the v.g.'s.
I'm very happy with them and have no regrets. I wish I had put them on sooner.
byoungplumbing(at)gmail.c
PostPosted: Tue Feb 06, 2018 4:09 pm    Post subject: V.G. update Reply with quote
Very comparable to the results that I had on my mklll
Boyd Young
On Feb 6, 2018 4:28 PM, "Rex Rodebush" <jrrodebush(at)gmail.com (jrrodebush(at)gmail.com)> wrote:
--> Kolb-List message posted by: "Rex Rodebush" <jrrodebush(at)gmail.com (jrrodebush(at)gmail.com)>
http://forums.matronics.com/viewtopic.php?p=477886#477886
WIKI -
