SDS injection and ignition, someone with experience on a 10?
glastar(at)gmx.net
PostPosted: Thu Feb 08, 2018 7:14 am    Post subject: SDS injection and ignition, someone with experience on a 10? Reply with quote
Hello,
I'm looking on probably not using a standard Lycoming IO setup instead
using a core engine with SDS fuel injection and ignition.
Anybody out there who has that setup running since a while and what are
your experience with it.
Thanks for your advice and information.
Cheers Werner
kearney
PostPosted: Thu Feb 08, 2018 9:19 am    Post subject: SDS injection and ignition, someone with experience on a 10? Reply with quote
Werner
I will be using an SDS system as well. Although I can help with your immediate query, I can say Ross who I have known for a few years / he is on my field - provides truly exceptional support.
If you all him directly he will give you accurate, honest info on his system.
Cheers
Les
On Feb 8, 2018, at 8:13 AM, Werner Schneider <glastar(at)gmx.net> wrote:
Hello,
I'm looking on probably not using a standard Lycoming IO setup instead using a core engine with SDS fuel injection and ignition.
Anybody out there who has that setup running since a while and what are your experience with it.
Cheers Werner
