saafbusiness(at)gmail.com Guest
Posted: Thu Feb 08, 2018 5:15 am Post subject: Pulsar-List Digest: 6 Msgs - 02/07/18 |
Ray,
In the beginning 21 years ago, I had to seal the rivets 2 or 3 times to get them to stop leaking They are sneaky
In the last 6 years, I had to reseal my tanks and recoat them as the ethanol I believe extracted or softened some of the resin. You can call me if you want more details 321-626-4786
There are 2 issues....the sealant and the flexing of the wing over time will leak at the root.
1 - I used PRC Desoto 1750 for 16 years then had to recoat and rebuild some of the wing
2 - I used the same PRC 1750 after rebuild
So far so good...
3 - In my opinion, you MUST apply the standard fix with layers carbon and glass (last page of PDF) or it will always leak do to wing flexing in flight
In the last 6 years, I have not had any leaks after applying this leak fix.
I will NEVER (knowingly) use gas containing ethanol again, only ethanol free or 100 LL with the TCP additive. The repair of the wings is not fun
On Thu, Feb 8, 2018 at 2:41 AM, Pulsar-List Digest Server <pulsar-list(at)matronics.com (pulsar-list(at)matronics.com)> wrote:
| Quote: | *
Today's complete Pulsar-List Digest can also be found in either of the
of the Pulsar-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2018-02-07&Archive=Pulsar
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2018-02-07&Archive=Pulsar
Pulsar-List Digest Archive
Total Messages Posted Wed 02/07/18: 6
Today's Message Index:
1. 12:24 PM - fuel tank leaks (Ray Wilhelm)
2. 12:56 PM - Re: fuel tank leaks (BARRY NORMAN)
3. 01:02 PM - Re: fuel tank leaks (Ray Wilhelm)
4. 01:07 PM - Re: fuel tank leaks (N3300P)
5. 01:10 PM - Re: fuel tank leaks (N3300P)
6. 01:14 PM - Re: fuel tank leaks (Ray Wilhelm)
Time: 12:24:44 PM PST US
From: Ray Wilhelm <rwilhelm25(at)gmail.com (rwilhelm25(at)gmail.com)>
Subject: fuel tank leaks
Any recommendations to seal the mounting screws that hold the tank end
plates on to the tank?
Ray
Time: 12:56:15 PM PST US
From: BARRY NORMAN <barrynorman(at)comcast.net (barrynorman(at)comcast.net)>
Subject: Re: fuel tank leaks
Ray,
I use the same poly sulfide that I use in the end plate itself.
Barry
> On February 7, 2018 at 3:23 PM Ray Wilhelm <rwilhelm25(at)gmail.com (rwilhelm25(at)gmail.com)> wrote:
> Any recommendations to seal the mounting screws that hold the tank end plates
on to the tank?
> Ray
Time: 01:02:09 PM PST US
Subject: RE: fuel tank leaks
That is what I used originally, also Barry. That was 20 years ago. Not sure
what it was and probably not available anymore?
Ray
Sent from Mail for Windows 10
Sent: Wednesday, February 7, 2018 12:58 PM
Ray,=C2-
Barry=C2-
es on to the tank?
Ray
________________________________ Message 4 _____________________________________
Time: 01:07:02 PM PST US
From: N3300P <n3300p(at)gmail.com (n3300p(at)gmail.com)>
I used these
http://www.theflightshop.com/Cataspx63.html
On Feb 7, 2018, at 2:23 PM, Ray Wilhelm <rwilhelm25(at)gmail.com (rwilhelm25(at)gmail.com)> wrote:
s on to the tank?
Ray
________________________________ Message 5 _____________________________________
Time: 01:10:48 PM PST US
For details Check page 19
https://www.theflightshop.com/Download/TheFlightShopCatalogrev12.pdf
On Feb 7, 2018, at 3:06 PM, N3300P <n3300p(at)gmail.com (n3300p(at)gmail.com)> wrote:
I used these
s on to the tank?
Ray
________________________________ Message 6 _____________________________________
Time: 01:14:53 PM PST US
That was a smart idea. I would use those if I needed to remove the plates.
Sent: Wednesday, February 7, 2018 1:09 PM
I used these
es on to the tank?
Ray
ar-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Pulsar-List
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
| Description: |
 Download |
| Filename: |
Fuel_tank_repair_OY-LLE.pdf |
| Filesize: |
176.73 KB |
| Downloaded: |
513 Time(s) |
rwilhelm(at)dc.rr.com Guest
Posted: Thu Feb 08, 2018 8:12 am Post subject: Pulsar-List Digest: 6 Msgs - 02/07/18 |
WOW !
That is some fix. I have not heard of any Pulsar III with leakage at the spare joint. Just XP’s. If the leak was at the spar joint it would be readily visible.
My leaks are strictly from the screws. So far, I believe the failure is from an insufficient amount of sealer applied to the heads of the screws.
Thank you for your input.
Ray
Sent: Thursday, February 8, 2018 5:14 AM
To: pulsar-list(at)matronics.com (pulsar-list(at)matronics.com)
Subject: Re: Pulsar-List Digest: 6 Msgs - 02/07/18
Ray,
So far so good...
On Thu, Feb 8, 2018 at 2:41 AM, Pulsar-List Digest Server <pulsar-list(at)matronics.com (pulsar-list(at)matronics.com)> wrote: | Quote: |
HTML Version:
Text Version:
Ray
Ray,
Barry
| Quote: | On February 7, 2018 at 3:23 PM Ray Wilhelm <rwilhelm25(at)gmail.com (rwilhelm25(at)gmail.com)> wrote:
on to the tank?
Ray
Ray,=C2-
Barry=C2-
es on to the tank?
Ray
I used these
s on to the tank?
Ray
Subject: Re: Pulsar-List: fuel tank leaks
I used these
s on to the tank?
Ray
I used these
es on to the tank?
Ray
FORUMS -
WIKI -
b Site -
n3300p(at)gmail.com Guest
Posted: Thu Feb 08, 2018 8:27 am Post subject: Pulsar-List Digest: 6 Msgs - 02/07/18 |
I understand now your just sealing the screw heads outside the tank. If you were sealing the end plate it might be best to use a sealant that will allow removal of the plate. One such sealant is PR 1428 B-2
http://www.aircraftspruce.com/catalog/appages/ppgsemkit09-04704.php
On Feb 8, 2018, at 10:11 AM, Ray Pulsar III/3300 <rwilhelm(at)dc.rr.com (rwilhelm(at)dc.rr.com)> wrote:
WOW !
Ray
Ray,
So far so good..
HTML Version:
Text Version:
Ray
Ray,
Barry
on to the tank?
Ray
Ray,=C2-
Barry=C2-
es on to the tank?
Ray
I used these
s on to the tank?
Ray
I used these
s on to the tank?
Ray
I used these
es on to the tank?
Ray
FORUMS -
WIKI -
b Site -
rwilhelm25(at)gmail.com Guest
Posted: Thu Feb 08, 2018 8:56 am Post subject: Pulsar-List Digest: 6 Msgs - 02/07/18 |
That is a terrific idea. I will keep that in the back of my mind for next time.
Ray
Sent: Thursday, February 8, 2018 8:31 AM
Subject: Re: Re: Pulsar-List Digest: 6 Msgs - 02/07/18
WOW !
Ray
Ray,
So far so good...
HTML Version:
Text Version:
Ray
Ray,
Barry
on to the tank?
Ray
Ray,=C2-
Barry=C2-
es on to the tank?
Ray
I used these
s on to the tank?
Ray
I used these
s on to the tank?
Ray
I used these
es on to the tank?
Ray
FORUMS -
WIKI -
b Site -
