oratex covering material
kenw
PostPosted: Thu Mar 01, 2018 5:31 am    Post subject: oratex covering material Reply with quote
I was researching Oratex covering for my MK3 Classic, does anyone have any experience with this product? please share... thank you
kenw
Rex Rodebush
PostPosted: Thu Mar 01, 2018 9:35 am    Post subject: Re: oratex covering material Reply with quote
I used the PolyFiber method but The July, 2014 issue of Kitplanes had a very good article on oratex. Google oratex kitplanes and it should come up.
victorbravo(at)sbcglobal.
PostPosted: Thu Mar 01, 2018 11:47 am    Post subject: oratex covering material Reply with quote
I have used this material on R/C model airplanes many times, not yet on a full-size aircraft. Reportedly, Oratex is significantly lighter and easier to use than the other systems (Stits Poly Fiber, Ceconite, etc.). More expensive UNTIL you compare the actual overall cost and time of the older systems. If your time is worth any more than two dollars an hour, Oratex should be a bargain even with the higher initial cost. Remember the "price" of Oratex includes all the dope, silver UV, and color paint.
Another very well liked "new" alternative is the Stewart Systems, which is water based and relatively inexpensive.
Bill Berle
On Thu, 3/1/18, Rex Rodebush <jrrodebush(at)gmail.com> wrote:
Subject: Re: oratex covering material
Date: Thursday, March 1, 2018, 9:35 AM
Rodebush" <jrrodebush(at)gmail.com>
up.
http://forums.matronics.com/viewtopic.php?p=478333#478333
The Kolb-List Email Forum -
Navigator to browse
List Un/Subscription,
7-Day Browse, Chat, FAQ,
    - MATRONICS WEB FORUMS -
via the Web Forums!
    - NEW MATRONICS LIST WIKI -
Email List Wiki!
  - List Contribution Web Site -
support!
George Alexander
PostPosted: Thu Mar 01, 2018 2:38 pm    Post subject: Re: oratex covering material Reply with quote
victorbravo(at)sbcglobal. wrote:
. S . N . I . P .
Bill Berle
. S . N . I . P .
Direct quote from the Stewart System Web Site:
"Our new, breakthrough coatings are not "water-based"-- they're waterborne. "
Helped re-covering of an Aeronca Chief and a Piper J3 Cub using the Stewart System.
George Alexander
FS II R503
E-LSA N709FS
http://www.oh2fly.net
capedavis(at)yahoo.com
PostPosted: Fri Mar 02, 2018 11:09 am    Post subject: oratex covering material Reply with quote
I am building a Firefly and am going to cover with ORATEX I bought the sample package from the and used it to cover a piece of a rudder that I had laying around the barn it worked great I was using an unmeasured heat gun and got one piece too hot turned a little brown ( it was. Cub yellow) but it was much easier than stitts which I covered my Firestar with 25 years ago there is no Oder from the materials no coating after coating
I would suggest you buy the sample kit $25 and experience it yourself if you don’t have all the machinery needed to do Stitts you might come out about even using Oratex as the air movers and compressor are not needed you could do it in your house without exposing yourself or your family to all those fumes ! Just my 2cents Chris Davis
kenw
http://forums.matronics.com/viewtopic.php?p=478330#478330
