victorbravo(at)sbcglobal. Guest
Posted: Mon Mar 05, 2018 10:28 am Post subject: Kolb-List:Windshield plastic crazing |
John H and Kolb List,
I'm no expert on the polycarbonates or acrylics, but could this crazing be from internal stress over time? Meaning that when you take a flat sheet and bend it into a curve, then fasten it down into that curved position (the shape of the Kolb nose cone), there is a small stress put into the plastic. Over a long period of time, perhaps the stresses eventually cause the internal cracks or difference in transparency?? This is a wild-a$$ guess on my part.
Most "airplane" windshields are thermoformed, heated until the plastic is soft, so perhaps the internal stress is not as much?
If this is not a viable explanation, perhaps the previous suggestion of a bad batch of plastic is the likely answer IMHO.
Most of the manufacturers have a website or some sort of tech help phone number where you can ask a technical question. They may have seen this problem before and have a useful answer.
Bill Berle
www.ezflaphandle.com - safety & performance upgrade for light aircraft
www.grantstar.net - winning proposals for non-profit and for-profit entities
On Mon, 3/5/18, John Hauck <jhauck(at)elmore.rr.com> wrote:
Subject: RE: Re: Kolb-List Digest: 6 Msgs - 03/01/18
Date: Monday, March 5, 2018, 9:11 AM
#yiv8117676239
#yiv8117676239 --
_filtered #yiv8117676239 {panose-1:2 4 5 3 5 4 6 3 2 4;}
_filtered #yiv8117676239 {font-family:Calibri;panose-1:2 15
5 2 2 2 4 3 2 4;}
_filtered #yiv8117676239 {font-family:Tahoma;panose-1:2 11
6 4 3 5 4 4 2 4;}
#yiv8117676239
#yiv8117676239 p.yiv8117676239MsoNormal, #yiv8117676239
li.yiv8117676239MsoNormal, #yiv8117676239
div.yiv8117676239MsoNormal
{margin:0in;margin-bottom:.0001pt;font-size:12.0pt;}
#yiv8117676239 a:link, #yiv8117676239
span.yiv8117676239MsoHyperlink
{color:blue;text-decoration:underline;}
#yiv8117676239 a:visited, #yiv8117676239
span.yiv8117676239MsoHyperlinkFollowed
{color:purple;text-decoration:underline;}
#yiv8117676239 p.yiv8117676239MsoAcetate, #yiv8117676239
li.yiv8117676239MsoAcetate, #yiv8117676239
div.yiv8117676239MsoAcetate
{margin:0in;margin-bottom:.0001pt;font-size:8.0pt;}
#yiv8117676239 span.yiv8117676239BalloonTextChar
#yiv8117676239 span.yiv8117676239EmailStyle19
{color:#1F497D;}
#yiv8117676239 span.yiv8117676239EmailStyle20
{color:#1F497D;}
#yiv8117676239 span.yiv8117676239EmailStyle21
{color:#1F497D;}
#yiv8117676239 .yiv8117676239MsoChpDefault
_filtered #yiv8117676239 {margin:1.0in 1.0in 1.0in 1.0in;}
#yiv8117676239 div.yiv8117676239WordSection1
#yiv8117676239 Jack H/Kolbers: Doubt the polishing kit would
correct my problem. The failure is in the generic
polycarbonate I used last time I replaced windshield and
doors. I think if I had stuck with more expensive GE
Lexan, I wouldn't be having this problem. Right now I am scratching my head
to figure out why this polycarbonate failed. One
possibility is a reaction to the last windshield cover I
made about 4 or 5 years ago. I found some heavy material,
similar to Naugahyde, at a local fabric shop. I was tired
of making new covers out of plastic table cloths every
year. My thought is there was a chemical reaction from the
gassing of the material used to make the material. Maybe
not. I don't know. Darn shame though. The surface
of the polycarbonate is in great shape. Thanks for the
suggestion. john hmkIIITitus, Alabama From:
owner-kolb-list-server(at)matronics.com
[mailto:owner-kolb-list-server(at)matronics.com] On Behalf
Of Jack Hart
Sent: Monday, March
05, 2018 10:13 AM
To:
kolb-list(at)matronics.com
Subject: RE:
03/01/18
John, I have had good luck with
using the headlight polishing kits that are sold at auto
parts stores. The kits are not expensive compared to a new
windshield. Try it on the windshield in a small area and
see if it helps out. Jack B. Hart
FF004 Winchester,
IN From: "John Hauck" <jhauck(at)elmore.rr.com>
Sent: Sunday, March 4, 2018 1:02 PM
Digest: 6 Msgs - 03/01/18 Chris D/Kolbers: -----my 1992 MKIII, is in need of
a lot of cosmetic TLC, especially the glass. The
windshield has started crazing which gives it the diamond
glare effect when flying into the sun.
Posted: Mon Mar 05, 2018 10:52 am Post subject: Kolb-List:Windshield plastic crazing |
Stress may very well be the culprit. Takes a lot of pressure to conform 1/8 polycarbonate to the nose pod and upper windshield frame. Doors are 1/16, but not much pressure to bend them to conform.
Thanks for the suggestion.
_________________ John Hauck
Titus, Alabama |
