danny shepherd
Joined: 27 Jan 2006 Posts: 117 Location: north Wales, United Kingdom
Posted: Tue Mar 06, 2018 6:47 am Post subject: ethanol |
Hi All,
A few years ago I bought a Ethanol testing kit. It consisted of a couple of small bottles and what looked like blue coloured cotton buds. I'm now down to my last couple of testing sticks, does any one know where I can get some more. I have tried all the usual aviation sites, but with no luck. I have looked through my old invoices but can't find them. Maybe the don't produce them any more .
Cheers Danny. G-c.e.r.i
hanaperrod
Joined: 21 Oct 2013 Posts: 11 Location: Isle of wight
Posted: Wed Mar 07, 2018 12:43 am Post subject: Re: ethanol |
Hi Danny.
Sounds like you had a test kit originally supplied by Airworld. ( now closed )
I use a kit supplied by Frost automotive supply company. www.frost.co.uk
E-test kit. It has a blue dye to add to the petrol/water mix that helps identify
the ethanol %.I check out all fuel purchased GULF petrol here on the I o W.
at the moment has no ethanol. Hope this helps.
Rod.
danny shepherd
Posted: Wed Mar 07, 2018 2:16 am Post subject: ethanol |
thanks Rod I'll have a look.
Cheers Danny.
On 07/03/2018 08:43, hanaperrod wrote:
Quote: | Quote: | --> Europa-List message posted by: "hanaperrod" <gilrod(at)tiscali.co.uk> (gilrod(at)tiscali.co.uk)
Hi Danny.
Rod.
http://forums.matronics.com/viewtopic.php?p=478443#478443
clivesutton
Posted: Wed Mar 07, 2018 3:14 am Post subject: Re: ethanol |
Hello Danny,
I have 24 of those cotton buds left from a 303381 fuel testing kit i brought from Airworld a few years ago. You are welcome to some if you can send me your address. Not sure if they have deteriorated with time (though they have been dry-stored in a sealed plastic bag).
In my view Bob Hitchcock's bottle mentioned as in a previous post (the function of which incidentally is replicated on most of those fuel-drain/screwdriver things us Aviators all buy during training) is probably the neatest solution - since it involves only mixing a small qty of fuel with a carefully measured sample of water and noting the change in relative levels due to mixing of part of the water sample with any alcohol (ethanol) existing in the fuel - an approach which also avoids buying and managing other test-related supplies.
Further, the bottle method should enable the amount of ethanol in the fuel to be determined and then compared to the acceptable percentage. I think the dye methods only indicates IF there is ethanol in the fuel, not how much.
Clive
JonSmith
Posted: Wed Mar 07, 2018 3:40 am Post subject: Re: ethanol |
Hi, I used to use the Airworld blue buds too which worked fine but not available now. Instead I use a droplet of food colouring in a small sample of fuel in a glass jar. If there is no ethanol the droplet stays completely separate, if there is ethanol the droplet dissolves and discolours the whole sample.
_________________ G-TERN
Classic Mono |
ptag.dev(at)talktalk.net Guest
Posted: Wed Mar 07, 2018 11:20 am Post subject: ethanol |
Hi! All.
I checked on the Frost site and spoke to a very helpful gent who explained
that their additive was meant to only protect against corrosion and needed
adding to all your fuel each bottle is sufficient for adding to 250 litres
of fuel !
However he kindly recommended me to an American site who produce a small kit
container which allows you to take a small sample from the water drain point
on the aircraft and if Ethanol is present it changes colour to blue (that is
the whole sample) . But it was expensive at about $ 35 per unit ! I paid by
Pay Pal and the final bill including postage and packaging finalised at
approx $70 , so I was scammed yet again !
Beware of wolves in sheep's clothing ( bastards) sorry but no other name in
my vocabulary .
So I can test a small amount from each fill up but need to effect similar
checks if I land away.
Bob Harrison G-OTAG
Hitchflight
Joined: 22 Feb 2018 Posts: 92 Location: Derbyshire, England
Posted: Thu Mar 08, 2018 12:16 am Post subject: Re: ethanol |
Hi Bob
Recommend the Briggs and Stratton. Simple low cost and effective. Small enough to be carried around.
One UK to two UK pounds. A sensible and cheap solution! And it is reusable!
If your local Lawn mower sales place does not stock the tool. Then private message me and I will provide you with the solution. Have one spare tester.
Bob
