		| Author | Message |
		| wdaniell.longport(at)gmai Guest
				|  Posted: Wed Mar 07, 2018 7:52 am    Post subject: Back instruments |   |
				| So the saga continues.
New Dynon screen installed and working fine.
 I chickened out of remodeling the entire instrument panel.  I have decided to install a cluster of 1.25" round instruments for back up.
 TachMAPOil tempOil pressAmmeter (I am going to install a hall effect sensor for the Dynon and use the shunt for the round gauge)Fuel pressure.
 Now you all educated me as to the fact that you cant run two gauges of a single resistive senders.
 It turns out that all temp senders are resistive.  Just for the info of anyone else who is doing this, UMA can make a dual sensor sender - one with two sensors with two different connections so that solves the temperature sender.
 However UMA tells me that voltage based senders can in fact power more than one gauge.  So the solution is simply to buy the round gauges and use the Dynon sensors kit to power both Dynon Screen and round gauges.
 Will
 William Daniell
 LONGPORT
 +57 310 295 0744
		| Back to top |  |
		| h&jeuropa
				|  Posted: Fri Mar 09, 2018 4:16 am    Post subject: Re: Back instruments |   |
				| Will,
 I have disassembled the VDO oil pressure sender that comes standard on a Rotax 914.  It is a resistive sender.
 Jim Butcher
		| Back to top |  |
				|  Posted: Fri Mar 09, 2018 6:03 am    Post subject: Back instruments |   |
				| Jim
Yup the VDO one is resistive but the Kavlico that Dynon sells one is voltage.
 Incidentally VDO also sells dual output oil pressure senders and dual output temperature senders.  As I understand it all thermocouple senders for the same rages are electrically equivalent so in theory a 0/300 dual output sender would be identical output to 0/300 single output.  Can anyone tell what thread the rotax uses for its temperature senders.  ACS says it is 10mm and a "normal" as opposed to NPT thread.  Is this correct?
 Will
 William Daniell
 LONGPORT
 +57 310 295 0744
 On Fri, Mar 9, 2018 at 7:16 AM, h&jeuropa <butcher43(at)att.net (butcher43(at)att.net)> wrote:
  	  | Quote: |  	  | --> Europa-List message posted by: "h&jeuropa" <butcher43(at)att.net (butcher43(at)att.net)>
 Will,
 Jim Butcher
 http://forums.matronics.com/viewtopic.php?p=478519#478519
 FORUMS -
 WIKI -
 b Site -
 -Matt Dralle, List Admin.
		| Back to top |  |
		| h&jeuropa
				|  Posted: Fri Mar 09, 2018 12:33 pm    Post subject: Re: Back instruments |   |
				| Will,
 The VDO temp sender uses M10x1.5 thread.
 Jim Butcher
		| Back to top |  |
				|  Posted: Fri Mar 09, 2018 1:03 pm    Post subject: Back instruments |   |
				| Jim
Thanks - I will provide an update once I have finished
 William Daniell
 LONGPORT
 +57 310 295 0744
 On Fri, Mar 9, 2018 at 3:33 PM, h&jeuropa <butcher43(at)att.net (butcher43(at)att.net)> wrote:
 Will,
 Jim Butcher
 http://forums.matronics.com/viewtopic.php?p=478527#478527
 FORUMS -
 WIKI -
 b Site -
		| Back to top |  |
