Original Black Plastic specification brake pipe.
ptag.dev(at)talktalk.net
PostPosted: Sat Mar 17, 2018 8:16 am    Post subject: Original Black Plastic specification brake pipe. Reply with quote
Hi! All,
I’m looking for a supply of the early specification black plastic brake pipe? I would appreciate any supply information since the pipe that Europa 2004 has sent is clearly a different diameter to that used in the original kit 337. I may be suffering metrication hassle ?
I am particularly concerned to compare working pressures of the two specifications.
The Outside diameter of the replacement pipe they have sent is 2.32 inches which does not fit the original fittings and olives.. And the original supply kit OD is 2.48inches which do fit precisely.
I initially need 36 inches to complete a trike brake system repair. If anyone has a piece they could spare I will pay them handsomely including postage .
Best regards
Bob Harrison G-PTAG Kit 337. ( issued in 1996)
rowlandcarson(at)gmail.co
PostPosted: Sat Mar 17, 2018 8:30 am    Post subject: Original Black Plastic specification brake pipe. Reply with quote
Bob - over 2 inches OD? Really? Or have you slipped a decimal point somewhere? I think I could believe 0.248 inch (roughly a quarter inch) OD, or about 6mm in new money.
in friendship
Rowland
| Rowland Carson ... that's Rowland with a 'w' ...
| <rowlandcarson(at)gmail.com> http://www.rowlandcarson.org.uk
| Skype, Twitter: rowland_carson Facebook: Rowland Carson
Burrilla
PostPosted: Sat Mar 17, 2018 9:17 am    Post subject: Original Black Plastic specification brake pipe. Reply with quote
Ive just gone out to the freezing workshop and measure it as 0.236 inch or nears as dammit 6mm diameter.
Don’t have any I can spare though.
Alan
in friendship
Rowland
ptag.dev(at)tiscali.co.uk
PostPosted: Sat Mar 17, 2018 12:31 pm    Post subject: Original Black Plastic specification brake pipe. Reply with quote
Yes Rowland , I have dropped a decimal point sorry everyone.
The requirement is for just under 1/4" diameter 0.248 inches diameter.
