Flattening 1-3/8 diameter tubing on split gear
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List
Harvey Plummer
PostPosted: Wed Apr 11, 2018 9:49 am    Post subject: Flattening 1-3/8 diameter tubing on split gear Reply with quote
How did those of you with a split gear flatten the ends of the 1-3/8" diameter
tubing? I do not have a press with which to do it.
- The Matronics Pietenpol-List Email Forum -
http://www.matronics.com/Navigator?Pietenpol-List
Harv, 485PB
jack(at)textors.com
PostPosted: Wed Apr 11, 2018 3:39 pm    Post subject: Flattening 1-3/8 diameter tubing on split gear Reply with quote
Harv, I heated with a torch then squeezed in a vice. Worked well.
Jack Textor
On Apr 11, 2018, at 12:49 PM, Harvey Plummer <plummerharvey(at)yahoo.com> wrote:
Harv, 485PB
http://forums.matronics.com/viewtopic.php?p=479273#479273
Catdesigns
PostPosted: Wed Apr 11, 2018 5:19 pm    Post subject: Re: Flattening 1-3/8 diameter tubing on split gear Reply with quote
This is how I did it (see attached). All it takes is a bench vice and heat. Makes flattening really easy.
Chris
2012_2_22.pdf
 Filename:  2012_2_22.pdf
 Filesize:  164.17 KB
 Downloaded:  114 Time(s)
Chris
Sacramento, CA
WestCoastPiet.com
oldbird
PostPosted: Wed Apr 11, 2018 7:03 pm    Post subject: Flattening 1-3/8 diameter tubing on split gear Reply with quote
A strong vice may work.
Semih​
On Thu, Apr 12, 2018 at 2:38 AM, Jack Textor <jack(at)textors.com (jack(at)textors.com)> wrote:
--> Pietenpol-List message posted by: Jack Textor <jack(at)textors.com (jack(at)textors.com)>
Jack Textor
> On Apr 11, 2018, at 12:49 PM, Harvey Plummer <plummerharvey(at)yahoo.com (plummerharvey(at)yahoo.com)> wrote:
> --> Pietenpol-List message posted by: "Harvey Plummer" <plummerharvey(at)yahoo.com (plummerharvey(at)yahoo.com)>
> Harv, 485PB
br> enpol-List" target="_blank" rel="noreferrer">http://www.matronics.com/Navigator?Pietenpol-List
_blank" rel="noreferrer">http://forums.matronics.com
WIKI -
lank" rel="noreferrer">http://wiki.matronics.com
target="_blank" rel="noreferrer">http://www.matronics.com/contribution
Semih Oksay
Harvey Plummer
PostPosted: Mon Apr 16, 2018 7:37 am    Post subject: Re: Flattening 1-3/8 diameter tubing on split gear Reply with quote
Thank you guys. Going to give heat and vise a try.
Harv, 485PB
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List All times are GMT - 8 Hours
