JabiruEngine-List Digest: 3 Msgs - 04/23/18
cffd66(at)yahoo.com
PostPosted: Tue Apr 24, 2018 6:34 am    Post subject: JabiruEngine-List Digest: 3 Msgs - 04/23/18 Reply with quote
Be careful with oil additives. For example, Avblend is not recommended as it dissolves some of the sealants used between the case halves, etc. I don't know about Sea Foam Deep Creep.
Chuck D.
From: JabiruEngine-List Digest Server <jabiruengine-list(at)matronics.com>
To: JabiruEngine-List Digest List <jabiruengine-list-digest(at)matronics.com>
Sent: Tuesday, April 24, 2018 1:41 AM
Subject: JabiruEngine-List Digest: 3 Msgs - 04/23/18
Today's complete JabiruEngine-List Digest can also be found in either of the
of the JabiruEngine-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2018-04-23&Archive=JabiruEngine
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2018-04-23&Archive=JabiruEngine
JabiruEngine-List Digest Archive
Total Messages Posted Mon 04/23/18: 3
________________________________ Message 1 _____________________________________
Time: 07:27:36 AM PST US
From: Bobby Paulk <bobbypaulk(at)comcast.net (bobbypaulk(at)comcast.net)>
Subject: compression
While doing my "Condition" inspection I found that #3 cylinder had dropped to 56
/ 80 on the differential compression gauge ( engine warm ). The other five were
72, 74, and 76 average. The leak is through the rings because I can hear it
in the Crankcase breather line to the catch can. The next day ( engine cold
) I put a pressure gauge on the cylinders and spun the engine with the starter.
All cylinders were up to 90 psi or above including the #3.
The engine is not using oil excessively ( about one to two ounces per hour ) and
the oil is clean - about the color of maple syrup after 25 hrs on it. I sprayed
all the cylinders with Sea Foam Deep Creep and am letting it sit until I
get back there to run it and check differential compression again.
Has anyone dealt with this problem or know how to fix. I plan on flying it for
a for an hour or two and try the differential compression test again.
Thanks for any input.
Bobby
Jabiru 3300 295 hrs.
Zodiac 601 B
________________________________  Message 2 _____________________________________
simmor2
PostPosted: Tue Apr 24, 2018 7:02 am    Post subject: JabiruEngine-List Digest: 3 Msgs - 04/23/18 Reply with quote
So, it was recommended to me to run the engine up in rpm fairly frequently to get the cylinders hot Enough to keep things clean. (Burning off carbon)
Just my 2 cents
- Rich
On Apr 24, 2018, at 1:36 AM, JabiruEngine-List Digest Server <jabiruengine-list(at)matronics.com> wrote:
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 18-04-23&Archive=JabiruEngine
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 18-04-23&Archive=JabiruEngine
Today's Message Index:
1. 07:27 AM - compression (Bobby Paulk)
2. 03:58 PM - Re: compression (Tex Mantell)
3. 07:31 PM - Re: compression (Tim Yoder)
Bobby
Zodiac 601 B
Time: 03:58:09 PM PST US
Subject: RE: compression
Whats sea foam?
Sent from Mail for Windows 10
Sent: Monday, April 23, 2018 10:26 AM
to 56 / 80 on the differential compression gauge ( engine warm ). The other
five were 72, 74, and 76 average. The leak is through the rings because I
can hear it in the Crankcase breather line to the catch can. The next day (
engine cold ) I put a pressure gauge on the cylinders and spun the engine
with the starter. All cylinders were up to 90 psi or above including the #3
=C2-The engine is not using oil excessively ( about one to two ounces per
hour ) and the oil is clean - about the color of maple syrup after 25 hrs
on it. I sprayed all the cylinders with Sea Foam Deep Creep and am letting
it sit until I get back there to run it and check differential compression
again.
for a for an hour or two and try the differential compression test again.
Bobby
Zodiac 601 B
________________________________ Message 3 _____________________________________
Time: 07:31:26 PM PST US
Sounds like you are doing the correct things prior to the next check.
On your next flight I would recommend high power setting to help clean
potential dirty rings.
Tim
From: owner-jabiruengine-list-server(at)matronics.com
<owner-jabiruengine-list-server(at)matronics.com> On Behalf Of Bobby Paulk
Sent: Monday, April 23, 2018 7:26 AM
dropped to 56 / 80 on the differential compression gauge ( engine warm
). The other five were 72, 74, and 76 average. The leak is through the
rings because I can hear it in the Crankcase breather line to the catch
can. The next day ( engine cold ) I put a pressure gauge on the
cylinders and spun the engine with the starter. All cylinders were up to
hrs on it. I sprayed all the cylinders with Sea Foam Deep Creep and am
letting it sit until I get back there to run it and check differential
compression again.
it for a for an hour or two and try the differential compression test
again.
Bobby
Zodiac 601 B
