The (Ground) Plane Truth
kearney
PostPosted: Thu May 03, 2018 4:47 pm    Post subject: The (Ground) Plane Truth Reply with quote
Hi
I'll be the first to admit that my knowledge of radio physics is exceptionally limited. This brings me to the question of ground planes. I am told that a ground plane does not require metal to metal contact with an antenna. Is this correct? The reason I ask is I am wondering if I should un-install antennas prior to paint?
Cheers
Les
carl.froehlich(at)verizon
PostPosted: Thu May 03, 2018 5:28 pm    Post subject: The (Ground) Plane Truth Reply with quote
Shoot fire, you might as well throw gas on the primer war fire....
Here is the deal. RF ground is a different animal from DC ground. I recommend you remove all external antennas prior to paint. After paint re-install the antennas using a star washer on the inside of the fuselage on the antenna mounting studs. Done.
I have years of running HF and VHF mobile antennas pumping out 100+watts that where on mag mounts. The mag mount itself had Mylar file between the magnet and the car - along with the car paint. This resulted in no metal to metal contact - Infinity DC resistance. The antennas were perfectly happy to be RF coupled to the car ground plane, just like RF is happy to pass through a capacitor. Add the star washer anyway just to have a locking device and a DC connection for noise (very low probability, but star washers are cheap).
But - no matter what you do check all antennas with a real antenna analyzer from the radio (so that you check your coax and all connectors). This is how you know stuff works before you fly. People call me up on radio problems and this is the first thing I do. I find broken antenna mounts, cut or pulled out coax and crimp connectors that are just ugly.
Have fun,
Carl
On May 3, 2018, at 5:47 PM, kearney <kearney(at)shaw.ca> wrote:
Hi
Cheers
Les
http://forums.matronics.com/viewtopic.php?p=479827#479827
kearney
PostPosted: Thu May 03, 2018 5:51 pm    Post subject: Re: The (Ground) Plane Truth Reply with quote
Thanks Carl.
I assume most avionics shops would have an analyzer. Is this correct?
Cheers
Les
Lenny Iszak
PostPosted: Thu May 03, 2018 6:06 pm    Post subject: The (Ground) Plane Truth Reply with quote
Les,
The ground plane does requires electrical contact with the base of the antenna.
Lenny
On May 3, 2018, at 8:47 PM, kearney <kearney(at)shaw.ca> wrote:
Hi
Cheers
Les
Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 450 hrs
PostPosted: Thu May 03, 2018 6:12 pm    Post subject: The (Ground) Plane Truth Reply with quote
Just find your local ham radio operator that has something like this: https://www.gigaparts.com/mfj-259c.html?gclid=EAIaIQobChMI6Niipvzq2gIVV4ezCh3UVAUBEAQYASABEgL2VPD_BwE
Better yep, get one for you local EAA chapter as a shared tool.
Carl
On May 3, 2018, at 6:51 PM, kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
--> RV10-List message posted by: "kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)>
Thanks Carl.
Cheers
Les
http://forums.matronics.com/viewtopic.php?p=479831#479831
_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
http://wiki.matronics.com[/url]<==========================; - List Contribunbsp; -Matt Dralle, List Admin.</===========================================================
Kelly McMullen
PostPosted: Thu May 03, 2018 7:01 pm    Post subject: The (Ground) Plane Truth Reply with quote
Waste of time Les. If you properly installed the antenna with gasket and/or sealant
the paint shop should properly mask the antenna, so it doesn't get painted.
The grounding will be unchanged. On most com antennas, the ground path is through
the 3 or 4 screws that attach the antenna to the doubler you put under the fuselage skin.
The clean way to do that is to install nut plates on the doubler, then rivet doubler to inside of fuselage skin.
That way the ground is with the nutplates and solid via rivets to fuselage.
Good installs include a bead of sealant around the outside edge of the antenna.
Good paint shops protect antennas throughout skin prep and painting.
That said, be certain they protect the wheel bearings from pressure washing, or repack the bearings before the
plane rolls out of the shop.
Kelly
Sent from my IBM-360 main frame
On Thu, May 3, 2018 at 5:47 PM, kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
Hi
Cheers
Les
WIKI -
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Bob Turner
PostPosted: Thu May 03, 2018 10:04 pm    Post subject: Re: The (Ground) Plane Truth Reply with quote
I usually agree with Carl, but not this time. Capacitive coupling at RF frequencies usually has low impedance but does introduce an undesirable phase shift. Mag mount car antennas can be designed to balance this shift out, and some feed techniques (a gamma match as used in the Archer design) use a capacitor to introduce a desired phase shift. But standard aircraft antennas need a zero phase shift connection to ground. A good connection between the coax braid and the ground plane will suffice for simple antennas (nothing but a wire in the base). If the base has a matching network, then it will also need a good connection to the braid.
Bob Turner
RV-10 QB
jesse(at)saintaviation.co
PostPosted: Fri May 04, 2018 4:14 am    Post subject: The (Ground) Plane Truth Reply with quote
I think the operative word is “should”. I have a plane in my hangar that is very nicely painted. However, the Paint shop painted over the data plate. It’s almost impossible to read it. Then they put their “painted by” sticker right next to the painted over data plate. What should happen is not always what does happen.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
jesse(at)saintaviation.com
[quote] On May 3, 2018, at 10:58 PM, Kelly McMullen <apilot2(at)gmail.com> wrote:
