Yak-List:
dsavarese0812(at)bellsout
PostPosted: Sat May 05, 2018 3:39 pm    Post subject: Yak-List: Reply with quote
Try grinding the sides of the open end wrench you would like to use to remove the nuts.  That means grind off the bulk of the material on the outside of the open end side. ie: make the sides flat. You may even have to heat and bend it just slightly.
It's SOP to have to make certain tools to make the job easier. Another example is the wrench to remove the nut on the front of the magneto which is just under the engine mount ring.
That's why Harbor Freight is in business... to provide.tools which are inexpensive that you won't feel guilty about grinding, cutting or heating and bending.
Dennis
To: yak-list(at)matronics.com
Sent: Saturday, May 5, 2018 1:31 PM
Subject:
Need to remove the shutters in yak 52 for paint. Dont have the correct tool
to remove the 4 bolts around the prop flange to remove. Everything else is
loose. Ideas?
