[SUSPECTED SPAM] Re: Cleveland Wheels - parts breakdown
Kelly McMullen
PostPosted: Sun May 06, 2018 9:37 am    Post subject: [SUSPECTED SPAM] Re: Cleveland Wheels - parts breakdown Reply with quote
Just to follow-up, Spruce does not carry the exact part number for the felt nor the molded seal. I haven't looked
elsewhere for the parts. They do carry those items for a generic Cleveland 6" wheel that should work fine.
Sent from my IBM-360 main frame
On Sat, May 5, 2018 at 5:46 PM, Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)> wrote:
--> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
It is the correct page. Note that the molded seals are nice, similar to what Matco uses on the nose wheel. However, be sitting down when you price those gems. Felt works fine, especially if you are going to re-pack the bearings every year. You are doing great. Watch your brake pads. Depending on amount of use, you may very well need to change pads before your next year is up.
On 5/5/2018 3:10 PM, David Saylor wrote:
Here ya go, Phil.  I think this is the page you're looking for.
Here's the whole catalog <http://www.parker.com/parkerimages/Parker.com/Literature/Aircraft%20Wheel%20&%20Brake%20Division/AWB%20Static%20Files%20for%20Literature/AWBPC0001.pdf>.
FORUMS -
WIKI -
b Site -
          -Matt Dralle, List Admin.
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
