Dynon Servo Wiring
MJKTuck(at)cs.com
PostPosted: Sun May 06, 2018 2:17 pm    Post subject: Dynon Servo Wiring Reply with quote
A question for Dynon avionic Europa builders,
The servo wiring diagram for the Dynon servos seems to indicate that
each power and ground wires from the servos should run and be connected
separately to the power source. As these servos are relatively close
together in my installation, can I not have them connected to single
power and ground wires, so I just have two wires running through the
fuselage to the panel rather than four? Maybe a single 20 AWG wire won't
be big enough to run power to both servos?
Similarly, the yellow disconnect wires are shown being connected to a
momentary switch but can I not just connect the two yellow wires
together at the servo end and have a single yellow wire running up to
the switch? As far as I can tell this is just a trigger to ground
through the switch so there is no real 'current' flowing through it as such.
Martin Tuck
Europa N152MT
erichdtrombley(at)juno.co
PostPosted: Mon May 07, 2018 7:15 am    Post subject: Dynon Servo Wiring Reply with quote
Hi Martin,
I too have both of my servos near each other. I ran only one wire bundle per the manual, as if you were installing only one servo. However, at the servo end I made a daisy chain so that I could extend the wire harness to the other servo. Then you only need one yellow disconnect wire run to a single switch on your panel or stick. Hope that makes sense.
Erich,
N28ET ClassicMono 914
Unbelievable German World War 2 Photo Shocks Americans
pro.naturalhealthresponse.com
http://thirdpartyoffers.juno.com/TGL3131/5af06cfa753ba6cf86b78st01duc
