				 Posted: Tue May 08, 2018 7:40 am    Post subject: Bus bar materials |
				At 10:03 PM 5/6/2018, you wrote:
   	  | Quote: | 	 		  Joe,
  Thank you for that calculation. It sounds like thicker material would be better.
  I think that I will try flattening a piece of copper tube. Any excuse to play with
  a hydraulic press and solder in the same day is a good excuse
  On Sun, May 6, 2018 at 9:43 PM, user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:  --> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)>
   The area of your bus bar is 0.025 x 0.5 = 0.0125 0.0125 equals 12,500 circular mills which is slightly bigger than 10 AWG. |
      "Circular mills" is a different kind of area. It's simply the diameter of
      a conductor in thousandths squared. 10AWG ~ 0.100" diameter
      or 100 mills. 100^2 is 10,000 hence the circular mill rating
      of 10,000. The real cross section of 10AWG is pi x radius^2
      or 0.05 x 0.05 x 3.14 = 0.0078 square inches.
      Circular mills are a unit of area PROPORTIONAL to cross
      section. The cross section of the cited brass bus
      bar is indeed 0.0125 Square Inches which is about
      1.5 times the cross section of a 10AWG solid wire . . .
      but let us consider another case:
      Suppose you have a wire 1.000 inches in diameter (1000 'mils').
      The CMA value for this conductor would be 1 million while the
      cross section would be 0.5 x 0.5 x 3.14 or 0.785 square inches.
      A bar having a cross section of 1.000 x 0.785 would have
      an area of 785,000 square mills . . . the same cross section as a
      1.000" diameter wire of 1,000,000 CMA.
      So when comparing the cross section of the bus with that of
      10AWG wire, be aware of the 0.785:1 ratio between square mills
      and circular mils.
      Another consideration in this thread is the relative conductivity
      of the materials being considered. Copper and brass have wide
      ranges of RESISTANCE. Resistance is the major driver in a conductor's
      ability to (1) transport the energy with acceptable losses and (2)
      carry the current while maintaining temperature rise below
      acceptable limits.
      Silver has a resistance of 1.6 uOhm/cu-cm
      Copper is something like of 1.7 uOhm/cu-cm
      Aluminum alloys . . . 3 to 6 uOhm/cu-cm
      Copper alloys (Brass) . . . . 6 to 10 uOhm/cu-cm
      Of all common materials for use as stud-to-stud bar
      construction, copper is electrically superior with brass trailing
      a distant 4th place.
      'Copper equivalent' brass bars may be fabricated
      by making the cross section ~4 times that of
      the copper one.
      Aluminum has been used in production aircraft with
      good success and only needs to be 2x fatter
      electrically . . . but is thermally superior
      for heat conduction . . . so copper and aluminum
      are about equal.
      The biggest caveat for using aluminum is to strive
      for gas-tight electrical joints . . . moisture present
      at the interface between differing alloys combined
  l   with oxygen promotes corrosion which in time can
      lead to joint failure. Coating the surfaces with some
      robust moisture barrier (DC4 or even WD40) before
      making up the joint will impeded moisture/oxygen ingress.
      For the instance that germinated this thread, I'll suggest
      that an aluminum bar cut from sheet or off the shelf
      extrusion is easy to fabricate . . . and the parallel
      surfaces go to achieving gas-tight interfaces of the
      made up joints. Copper sheet good too. Mashing copper
      tube is kinda good if you can really put the mash on
      the material between PARALLEL jaws.
      If it were my airplane, I'd go for aluminum sheet
      with some good 'dope' in the joints. Aluminum is a
      whole lot easier  to drill!
  |  | - The Matronics AeroElectric-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		art(at)zemon.name Guest
				 Posted: Tue May 08, 2018 6:15 pm    Post subject: Bus bar materials |
				On Tue, May 8, 2018 at 10:39 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
  	  | Quote: | 	 		       If it were my airplane, I'd go for aluminum sheet
 Bob​,
 ​That's good to know. I have a whole boatload of scrap aluminum.​
 When you say "dope," do you mean dielectric grease like this: https://www.homedepot.com/p/CRC-3-3-oz-Technician-Grade-Dielectric-Grease-05113/206843029 ?
     -- Art Z.
 https://CheerfulCurmudgeon.com/"If I am not for myself, who is for me? And if I am only for myself, what am I? And if not now, when?" Hillel
		BARRY CHECK 6
				 Posted: Wed May 09, 2018 7:55 am    Post subject: Bus bar materials |
				Art:
 The term is Electrical DUCK Grease; it is just the opposite of Dielectric
 Grease.
 It is a CONDUCTOR grease which usually has very fine copper or silver dust
 in it.
 I doubt if silver is available today as the cost would be ridiculously high
				 Posted: Wed May 09, 2018 1:06 pm    Post subject: Bus bar materials |
    I checked the SDS on this stuff . . . it's a very
    close cousin to the Dow Corning product I mentioned.
    It would be fine.
				 Posted: Wed May 09, 2018 1:28 pm    Post subject: Bus bar materials |
				At 09:34 AM 5/9/2018, you wrote:
   	  | Quote: | 	 		  Art:
  The term is Electrical DUCK Grease; it is just the opposite of Dielectric Grease. |
    We're talking different materials that serve
    two different purposes. There are useful materials to
    add to joints in rigid components common to high
    power technologies like submarines, sub-stations
    etc. These not only exclude moisture, they contain
    electrically conductive enhancements for crossing
    voids that cannot be closed with tension in the
    bolts.
    Then there are treatments intended to fill tiny gaps
    between mated surfaces to prevent ingress of water/oxygen
    that progressively degrades the joint. I have a tube
    of Dow Corning DC4 that has lasted about 40 years
    . . . it doesn't take much. It's used to thinly coat
    mating surfaces of DUCTILE terminals. Any DC4 caught
    in the squash on the two metals is simply extruded out.
    But the tiniest voids in the interface will remain
    completely filled with DC4. Other, non-reactive
    materials would work too. Axle grease is better
    than nothing. The CRC product cited is good.
				 Posted: Wed May 09, 2018 6:19 pm    Post subject: Bus bar materials |
 Thanks for the info. I will opt for the CRC from the local Home Depot instead of paying shipping for DC4.
     -- Art Z.
 On Wed, May 9, 2018 at 4:27 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
  	  | Quote: | 	 		    At 09:34 AM 5/9/2018, you wrote:
   	  | Quote: | 	 		  Art:
    bolts.
		BARRY CHECK 6
				 Posted: Fri May 11, 2018 5:16 am    Post subject: Bus bar materials |
				Bob:
 The question that Art brought up is due to inconsistency in terms; you used the term 'dope'.
 From Art's question I gathered he wanted to do two things:
 1 - Insure electrical contact and
 2 - Prevent corrosion due to the elements and dissimilar materials.
 I agree we, are talking two different products.
 Dow Corning DC 4 is a Dielectric Grease.
 By definition and manufactures recommendations it is used to COAT a joint in preventing contact by the elements.
 Dielectric means INSULATE.
 It does NOT improve the conductive properties of metals or dissimilar metals.
 It protects them from the elements.  Which is a good thing if that is all you want to do.
 The product which has the industry nickname DUCK GREASE does BOTH - Protect and Ensure electrical conductivity, especially between dissimulator metals.
 Personally I think this particular coating process is just a bit beyond normal requirements.
 Why?  Well, I would have to ask:  Is the owner going to REPEAT the exact same process every Annual/Safety Inspection?
 Remove/open the entire connection, clean the mating areas, replace the lock-washers and re-coat the area [with what ever process he deems acceptable]?
 Human Nature and 20+ years working on peoples planes, says: No!
 Considering how DUCK GREASE is used, it does not require replacement and it is used between mating parts.  BUT!  I still think it is Belts & Suspenders and Shoelaces.
 Many of the certified planes out there are around 40 years old.  They nBarryow have a history.  Those connections were NOT opened every Annual/Safety Inspection.  Yet!  They continue to work!
 If the additional coating process extends the unknown life of the connection / plane ...  GREAT!  We will see in 41 years.  LoL!
 And Art...  If you want to obtain Dielectric Grease it can be purchased at Auto Stores, it comes in a Yellow Packet, packaged by Permatex.  Cost: About $1.00.
 Duck Grease is not as easy to find.  Electrical Supply Outlets - It comes in a squeeze bottle usually with a red label and white writing.
 Barry
 On Wed, May 9, 2018 at 5:27 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
   	  | Quote: | 	 		  Art:
    bolts.
				 Posted: Fri May 11, 2018 8:51 am    Post subject: Bus bar materials |
				At 08:14 AM 5/11/2018, you wrote:
   	  | Quote: | 	 		  Bob:
  It protects them from the elements.  Which is a good thing if that is all you want to do. |
    That IS all I want and expect it do to . . .
   	  | Quote: | 	 		  The product which has the industry nickname DUCK GREASE does BOTH - Protect and Ensure electrical conductivity, especially between dissimulator metals.
  Remove/open the entire connection, clean the mating areas, replace the lock-washers and re-coat the area [with what ever process he deems acceptable]? |
    Yeah . . . AC43.13 used to have a paragraph or
    two about  "inspection of bus bars . . . with
    recommendations for refurbishment on condition.
    If any combination is assembled to specs and remains
    tight, then there is no reason to 'inspect'. This applies
    to every rivet in the airplane, all the fasteners in
    the engine, etc. etc.
   	  | Quote: | 	 		  Human Nature and 20+ years working on peoples planes, says: No!
  between mating parts.  BUT!  I still think it is Belts & Suspenders and Shoelaces. |
    When you simply twist two strands of freshly
    exposed wire together in the classic 'Western
    Union" telegraph splice . . . that joint is
    presently as good as it will ever be. The
    telegraph guys didn't solder them because tension
    on the suspended wires maintained gas-tight
    connections where the forces peaked on the
    interfaces.  Solder was later used to enhance
    integrity from environmental stresses . . .
    an excellent encapsulation that protected
    the edges of the regions of gas-tightness.
    DC4 or any other material used in the interface
    of devices on threaded fasteners does the same
    thing.  The day that the assembly is made up
    brand new . . . is as good as that joint is
    ever going to be. Now, if the fastener stays
    tight and DC4 (or other good stuff) protects
    the boundaries of gas-tightness . . . the join's
    integrity will not degrade with age.
  connection / plane ...  GREAT!  We will see in 41 years. |
     My point exactly. We did not use ANY goops, greases,
     magic juice or pixie dust in the assembly of
     production airplane. The goal was to create joint
     with a life expectancy longer than the airframe
     itself . . . with, what you have observedis a
     high degree of success.
     DUCK grease may well be belt, suspenders and shoe
     laces . . . but DC4 (or equal) is at least belt and
     suspenders and probably useful in the most exposed
     joints . . . like those ground screws on an antenna?
