Orientation of NAV/VOR antenna compared to COM antenna
Burrilla
PostPosted: Wed May 16, 2018 10:36 pm    Post subject: Orientation of NAV/VOR antenna compared to COM antenna Reply with quote
VOR Signals are Horizontally polarised and VHF COM Vertical.
Alan
On 17 May 2018, at 03:40, Christoph Both <christoph.both(at)acadiau.ca> wrote:
Very helpful advice, thank you!
Now, the question remains, is it better to orient the antenna horizontally for NAV, compared to vertically for COM?
Christoph
On 2018-05-16, 11:26, "owner-europa-list-server(at)matronics.com on behalf of AirEupora" <owner-europa-list-server(at)matronics.com on behalf of AirEupora(at)sbcglobal.net> wrote:
BOB Archer makes a whole set of antennas for glass aircraft. Aircraft Spruce sells them. I put my VOR antenna in the wing. I can get a good signal fifty to sixty miles away.
http://www.aircraftspruce.com/catalog/avpages/archer_antenna7.php?clickkey=5123597
I hope you have not closed out your wing. If you have then you could built a Balun antenna.
http://www.aeroelectric.com/articles/BALUN/Balun_Fabrication.html
http://forums.matronics.com/viewtopic.php?p=480170#480170
