Orientation of NAV/VOR antenna compared to COM antenna
grahamsingleton(at)btinte
PostPosted: Thu May 17, 2018 1:37 am    Post subject: Orientation of NAV/VOR antenna compared to COM antenna Reply with quote
it is better oriented horizontal for NAV because the NAV signal is horizontally polarised, comm is vertically polarised hence the vertical 1/2 wave antenna in the fin.
Graham
On Thursday, 17 May 2018, 7:37, Alan Burrill <alanb(at)dpy01.co.uk> wrote:
--> Europa-List message posted by: Alan Burrill <alanb(at)dpy01.co.uk (alanb(at)dpy01.co.uk)>
VOR Signals are Horizontally polarised and VHF COM Vertical.
Alan
On 17 May 2018, at 03:40, Christoph Both <christoph.both(at)acadiau.ca (christoph.both(at)acadiau.ca)> wrote:
--> Europa-List message posted by: Christoph Both <christoph.both(at)acadiau.ca (christoph.both(at)acadiau.ca)>
Very helpful advice, thank you!
Now, the question remains, is it better to orient the antenna horizontally for NAV, compared to vertically for COM?
Christoph
On 2018-05-16, 11:26, "owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) on behalf of AirEupora" <owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) on behalf of AirEupora(at)sbcglobal.net (AirEupora(at)sbcglobal.net)> wrote:
--> Europa-List message posted by: "AirEupora" <AirEupora(at)sbcglobal.net (AirEupora(at)sbcglobal.net)>
BOB Archer makes a whole set of antennas for glass aircraft. Aircraft Spruce sells them. I put my VOR antenna in the wing. I can get a good signal fifty to sixty miles away.
  http://www.aircraftspruce.com/catalog/avpages/archer_antenna7.php?clickkey=5123597
I hope you have not closed out your wing. If you have then you could built a Balun  antenna.
http://www.aeroelectric.com/articles/BALUN/Balun_Fabrication.html
  http://forums.matronics.com/viewtopic.php?p=480170#480170
http://www.matroni================
-= --> http://wiki.matronics.comhttp://www.=====
PostPosted: Thu May 17, 2018 10:08 am    Post subject: Orientation of NAV/VOR antenna compared to COM antenna Reply with quote
Hello Alan,
Thank you for your response. Very helpful.
Best,
Christoph
On 2018-05-17, 03:36, "owner-europa-list-server(at)matronics.com on behalf of Alan Burrill" <owner-europa-list-server(at)matronics.com on behalf of alanb(at)dpy01.co.uk> wrote:
Alan
> On 17 May 2018, at 03:40, Christoph Both <christoph.both(at)acadiau.ca> wrote:
> Christoph
> On 2018-05-16, 11:26, "owner-europa-list-server(at)matronics.com on behalf of AirEupora" <owner-europa-list-server(at)matronics.com on behalf of AirEupora(at)sbcglobal.net> wrote:
