Radio or Television Tower Buzz
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List
mike>bentley
PostPosted: Sun May 20, 2018 7:38 am    Post subject: Radio or Television Tower Buzz Reply with quote
When flying in the vicinity of radio or TV towers, I get a constant buzz or static over the radio. Sometimes I can hear the conversation or music from the station, but just barely. It seems to start when I'm within a 1/2 to 1/4 mile from a tower.
Anyone else have this type of issue or resolved this type of issue?
- The Matronics Avionics-List Email Forum -
http://www.matronics.com/Navigator?Avionics-List
Mike Bentley
Joplin, MO
N5498B
Kitfox Model 4-1200
Jabiru 2200 #438
Rotec Aerosport LCH Heads
Prince Prop (64 x 34)
Ellison EFS-2 Throttle Body
Kellym
PostPosted: Sun May 20, 2018 8:04 am    Post subject: Radio or Television Tower Buzz Reply with quote
What is happening is that the high power from the towers is exciting one
of the oscillators in one of your radios. What is most common,
especially with older 121.5 ELTs is for their transmit oscillator to be
activated by the high power RF from the towers, generating a weak white
noise signal that breaks squelch on your com radio. I used to have that
problem with a previous aircraft, where there are about 15 high power
towers on a mountain a few miles south of the Phoenix Class B and in
line with the VFR transition through the Class B. Communications with
approach control while flying that transition would become very
difficult. Newer 121.5 ELTs and 406 ELTs are better shielded for that.
Also, moving a com antenna from top of fuselage to belly can help
isolate the ELT from the com antenna.
Mike Bentley
Joplin, MO
N5498B
Kitfox Model 4-1200
Jabiru 2200 #438
http://forums.matronics.com/viewtopic.php?p=480245#480245
Kelly McMullen
KCHD
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List All times are GMT - 8 Hours
