pete(at)lawless.info Guest
Posted: Mon May 21, 2018 1:55 am Post subject: Rotax 912 Carburetor - Possible to purchase a few O-Rings? |
Hi Graeme
You could try MotoBins.
https://www.motobins.co.uk/displayfinal.php?function=show&subs=084&title=DIAPHRAGMS+%26+GASKETS
Pete
G-RMAC Classic #109
On 21/05/18 10:11, graeme bird wrote:
Quote: |
This old link no longer works; would the motorworks part be FUA35001J?
Bing carb for BMW R45 Pre 1981? Skydrive are out of stock of carb refurb kits
My 340hr/6 year old 912ULS missed a fraction of a beat a couple of times on Sat after running smoothly for over an hour, and spaced by maybe 20 minutes. Warm air, high presume no cloud and 3000ft in steady cruise, fuel filtered, filter changed recently, service 40hrs ago, fuel esso supreme. Wondered if it could be air pocket?
I'll change plugs, check plug sockets, carbs, filter, check fuel drain, clean air filter.
Suspect carb/fuel flow debris issue.
Graeme Bird
G-UMPY - Mono Classic/XS FFW 912S, Woodcomp 3000/3W CS, trutrak Gemini 2 axis AP, PAW, PFLARM core, ads-b out, 8.33khz, mode S, FP-5, Aera500, SD on Nexus, SmartA3
325 hours & 6 years on the Mono, 930 total
g(at)gdbmk.co.uk
http://forums.matronics.com/viewtopic.php?p=480272#480272
