wdaniell.longport(at)gmai Guest
Posted: Wed Jun 06, 2018 12:32 pm Post subject: UMA differential pressure sender with Dynon Skyview |
Does anybody know whether its possible to use the 0-7PSI differential pressure gauge (measure difference between airbox and fuel pressure for 914) with dynon skyview
thanks
Will
William Daniell
LONGPORT
+57 310 295 0744
ploucandco
budyerly(at)msn.com Guest
Posted: Wed Jun 06, 2018 4:29 pm Post subject: UMA differential pressure sender with Dynon Skyview |
Will
0-30 is the norm for the 914, on yours a 0-15 psi is OK as you run lower pressure. Dynon uses a Kavico sender.
Differential of 7 psi is OK.
Bud Yerly
Custom Flight Creations
Sent: Wednesday, June 6, 4:36 PM
Subject: UMA differential pressure sender with Dynon Skyview
thanks
Will
William Daniell
LONGPORT
+57 310 295 0744
erichdtrombley(at)juno.co Guest
Posted: Thu Jun 07, 2018 12:06 am Post subject: UMA differential pressure sender with Dynon Skyview |
Hi Will,
I use the UMA differential pressure sender (UMA N1EU07D) with my Dynon Skyview. Works very well. I tied into the fuel circuit on the outlet side of the Rotax fuel pressure regulator using a longer duel banjo bolt and fitting. And, used a vacuum tee at the Rotax air box pressure sensor.
Erich Trombley
N28ET Classic Mono 914
Good Morning America Confirms Unfortunate News
greatsuperstars.world
http://thirdpartyoffers.juno.com/TGL3131/5b18e5bf588a865bf0c55st04vuc
Posted: Thu Jun 07, 2018 11:23 am Post subject: UMA differential pressure sender with Dynon Skyview |
EricThanks
Can you give me the set up steps please
Ive changed sensor input mapping to the uma diff press gauge but the widget doesnt move. I think im missing a step.
Will
On Thu, Jun 7, 2018, 03:08 Erich Trombley <erichdtrombley(at)juno.com (erichdtrombley(at)juno.com)> wrote:
| Quote: | --> Europa-List message posted by: Erich Trombley <erichdtrombley(at)juno.com (erichdtrombley(at)juno.com)>
Hi Will,
Erich Trombley
pa-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Europa-List
WIKI -
Posted: Mon Jun 18, 2018 1:12 pm Post subject: UMA differential pressure sender with Dynon Skyview |
For all those that have this challenge in the future the issue was the power supply. The power supply to the Kavlico sender is 5v and the UMA needs 12v. As soon as I gave it 12v it woke up and worked as advertised.
Will
William Daniell
LONGPORT
+57 310 295 0744
On Wed, Jun 6, 2018 at 7:29 PM, Bud Yerly <budyerly(at)msn.com (budyerly(at)msn.com)> wrote:
| Quote: | Will
Bud Yerly
thanks
Will
William Daniell
LONGPORT
+57 310 295 0744
