Placement options for CHT probe
ceengland7(at)gmail.com
PostPosted: Thu Jun 07, 2018 6:22 pm    Post subject: Placement options for CHT probe Reply with quote
On 6/7/2018 8:35 PM, John Fitt wrote:
Greetings from Sebastopol, CA
Has anybody used a cylinder head bolt ( immediately next to a spark plug) instead of the probe ring
under the plug? I am currently using the cylinder head bolts, wanting to eliminate the wear and tear
on the probe ring when checking/changing plugs. Seems that the temp. readings are lower- maybe due to the heat lost near a fin?
FSII 503 dcdi
EIS monitor
CHT runs around 100-120 deg
John Fitt
From the Lycoming world: Washer-based cht probes on the plugs always indicate significantly higher than probes screwed into the heads. The plug is the hottest spot in the cylinder.
rascaljohn
PostPosted: Thu Jun 07, 2018 8:23 pm    Post subject: Placement options for CHT probe Reply with quote
Thanks for the reply. Any way to save on the wear and tear?
On Jun 7, 2018, at 7:22 PM, Charlie England <ceengland7(at)gmail.com (ceengland7(at)gmail.com)> wrote:
FSII 503 dcdi
EIS monitor
John Fitt
gdhelton(at)gmail.com
PostPosted: Fri Jun 08, 2018 7:32 am    Post subject: Placement options for CHT probe Reply with quote
Your CHT seems very low. Do you have your EIS set for centigrade or Fahrenheit?The most common cause for the disfigurement of spark-plug base rings is over- torque of spark plugs. I was surprised to find out that my engine ( 40hp Hirth 2702 ) only requires 108 inch pounds ( yes, inch pounds) of torque and with the spark-plugs seal ring installed with no anti- sieze compound.
George H.
Mesick, Michigan
On Jun 8, 2018, at 12:23 AM, John Fitt <jpfitt(at)sbcglobal.net (jpfitt(at)sbcglobal.net)> wrote:
FSII 503 dcdi
EIS monitor
John Fitt
racerjerry
PostPosted: Sat Jun 09, 2018 3:18 am    Post subject: Re: Placement options for CHT probe Reply with quote
Why don't you do a side-by-side test / comparison with the CHT probes in both locations on the same cylinder? A double throw switch temporarily wired in would give you an immediate comparison.
Jerry King
