Yak 50 airspeed indicator redline?
jbsoar(at)gmail.com
PostPosted: Fri Jun 08, 2018 3:18 pm    Post subject: Yak 50 airspeed indicator redline? Reply with quote
Does anyone know of a source for the proper airspeed indicator placards for a Yak 50.  Is just a redline used?  Is a yellow arc ever used on the Yak 50?Thank you.
John B
richard.goode(at)russiana
PostPosted: Sat Jun 09, 2018 2:05 pm    Post subject: Yak 50 airspeed indicator redline? Reply with quote
I could be wrong, but I don't think I've ever seen either a yellow or red arc on a 50.
Richard Goode Aerobatics
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
Tel:  +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of John B
Sent: 09 June 2018 00:09
To: Yak-List Digest Server <yak-list(at)matronics.com>
Subject: Yak 50 airspeed indicator redline?
Thank you.
John B
j.mevis(at)computer.org
PostPosted: Sat Jun 09, 2018 10:33 pm    Post subject: Yak 50 airspeed indicator redline? Reply with quote
Richard is correct, the original instruments  don’t have a coloured arc.
Today in EASA-Europe, it depends what must be done. Each country has other rules for Annexe II aircraft.
Generaly, if the plane is registered as an oldtimer (the definition varies between the members states of the EU), then it’s not necessary to modify the airspeed indicator.
In all other cases, even for non-certified aircraft, the airspeed indicator must follow the rules as for certified aircraft.
We have a French registered Yak 52 at our airfield and on this plane we had to modify the instrument.
We did it the easy way, painting the outer ring of the instrument.
Jan Mevis
From: <owner-yak-list-server(at)matronics.com> on behalf of Richard Goode <richard.goode(at)russianaeros.com>
Reply-To: <yak-list(at)matronics.com>
Date: Saturday, 9 June 2018 at 10:31
Subject: RE: Yak 50 airspeed indicator redline?
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
Thank you.
John B
Viperdoc
PostPosted: Sun Jun 10, 2018 11:11 am    Post subject: Yak 50 airspeed indicator redline? Reply with quote
Vne 450. Never seen a yellow or red arc on the ASI.Doc
On Jun 9, 2018, at 3:31 AM, Richard Goode <richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)> wrote:
<![endif]--> <![endif]-->
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) [mailto:owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)] On Behalf Of John B
To: Yak-List Digest Server <yak-list(at)matronics.com (yak-list(at)matronics.com)>
Thank you.
John B
Viperdoc
