		| Author | Message |
		| wlannon(at)shaw.ca Guest
				|  Posted: Sun Dec 23, 2018 2:14 pm    Post subject: Huosai intake tube leakage |   |
				| See JL2A’s post re cracking around # 4, 5 & 6 cyl intake drain ports on  the Huosai engine..
 If you have modified these intake tubes to accept a quick drain system  without first reinforcing the tubes you are a candidate for this failure.   It is a job for a good aircraft alum. welder.  Patches have to be formed  and fitted to the tube and the plug boss prior to welding.
 The problem arises since the Chinese weld here does not account for the  sharp change in cross section between the plug boss and the very thin wall of  the tube.
 It is adequate (but questionable!) for the original design only.  The  addition of a drain fitting, or even a hose leading to a drain fitting, is  enough to change the dynamics and introduce fatigue cracking around the  boss.
 This is not a new problem by any means but since I have done no complete  restorations in recent years I had forgotten about it.   I recent  years I look after only my
 own CJ (modified 20+ years ago) and two others with M14P engines which were  properly reinforced in production.  Have to admit old age may have some  bearing
 here as well.
 Walt
  Virus-free. www.avast.com 		 	 [url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
 | |  |  | - The Matronics Yak-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Yak-List
		| Back to top |  |
