Z19 first try and smoke/wire melted I did a mistake
PostPosted: Sun Jun 17, 2018 7:30 am    Post subject: Z19 first try and smoke/wire melted I did a mistake Reply with quote
At 08:56 PM 6/16/2018, you wrote:
--> AeroElectric-List message posted by: "Achille" <mickael.t(at)live.fr>
Thank you bob for you reply. I hope to find just the diode end the wire U/S. Many thanks.
I have to check just the integrity of contactor ground wire (master switch to the ground bus) easily accessible or I could have other wire damaged ?
If the burned wire is in a bundle, there is a
probability for damage to adjacent wires that
should be investigated.
Because all my wires are set in harness with sleeve.
. . . oh . . . fooey. Not an enviable task.
You might open just a portion of the sleeved
bundle for inspection. Find the contactor control
wire as assess damage to it's insulation and
propagation of damage to other wires.
About the possible damage, with luck just this wire and diode. But without
Alternator diode couldn't be damage at least ?
No, it's unlikely that the rest of the
system suffered any damage. To connect the
battery to the system, you have to close the
battery contactor. When battery power is
backwards, the diode across the contactor
coil is essentially a dead short across the
coil. If the diode is small (like a plastic
1N4000 series) it may simply explode and
remove itself from the equation. Not good.
Then the contactor coil closes and reversed
power is applied to the. This still isn't
an automatic condition for total distaster.
The alternator diode array will now become
reverse biased. The array is 6 to 9 diodes
in series pairs that will (1) prevent the
bus voltage from rising to more than a couple
volts . . . for a short period of time. The
b-lead protection device will operate and
disconnect the alternator from the bus.
After this time, all bets are off. But bus
voltage does waayyyy negative to what ever
the battery supplies.
If your contactor diode is mechanically
intact AND the control wire is burned, this
tells us that the contactor never closed.
You'll also find that your b-lead protection
is closed.
and my ignitions and transpondeur ? (I checked on the user manuel they told that inversion of polarity damage it) But in the case of switch was in OFF on the transpondeur (for exemple) it can damage it ? (I ask the question because I was doing a quote of my error to be prepared in the event of I have to change part.. and total price become quickly crazy)
I think your misery for having suffered this
event will be limited to inspection and repair
of the burned wire and replacement of the
contactor coil suppression diode.
PostPosted: Mon Jun 18, 2018 5:40 am    Post subject: Z19 first try and smoke/wire melted I did a mistake Reply with quote
At 03:52 PM 6/17/2018, you wrote:
It does not matter what kind of arc suppression device is in parallel with the contactor coil. That coil is going to energize when the switch is turned on (unless the master switch wire burns open). A diode in series with the contactor coil would prevent it from being energized by a reverse polarity battery. If a builder were concerned about reverse polarity, two diodes could be used, one in parallel with the coil and one in series. But what about protection against line boys with 24 volt jumper cables?
Yeah, I had a line-crew feller hook 28v to my 14v
172XP for a start assist on a -5C morning in KC.
He had his back turned to me and the WWII surplus,
gas driven generator was pretty noisy so yelling
was futile.
I hit the starter and got a really energetic engine
start. Only then did he hit the disconnect switch
never having looked at me. I wanted to get out and
. . . well . . . but that would have called for
stopping the engine. A quick check of the panel didn't
show evidence of damage so I chalked it up to experience
and future planning:
Me: You know this is a 14v airplane, right?
LB: Sure
Me: you know that you're not to take your eyes off
me, or take your fingers off the switch at any
time external power is on the airplane?
LB: Yeah, sure.
Me: You know that power doesn't go ON until I give
you a thumbs up?
LB: I can do that.
Me; You know that thumbs down means turn it OFF?
Lb: Okay.
Me: You're a bright fellow.
Then I tip him $5 and invite him to have a beer
on me.
REAL airplanes have ground power jacks fitted with
polarity protection, ov protection and CREW CONTROLLED
ground power contactors.
https://goo.gl/xzixnk
https://goo.gl/CbPgUw
Achille
PostPosted: Mon Jun 18, 2018 9:38 am    Post subject: Re: Z19 first try and smoke/wire melted I did a mistake Reply with quote
I will advise you this weekend I will asses.
The contactor wire is the only one that is alone, so it will be easy to change it if it's the only one that could be damage. In my mind it don't keep clear my mistake that it do du to lack of knowledge. I will see.
For the protection i checked user manuel the only one things that have a protection for reversal is my old becker AR3201 that I have to change it before august 2018 du to eupean rules..
I hope you have right bob and I have no doubt. Just i did the quote in case of...
I was thinking about one things. My ignitions have the case grounded and have the ground wire, both are grounded on the ground buses. I don't have short cut the ignition module ?
 Filesize:  119.98 KB
 Viewed:  8696 Time(s)
PostPosted: Mon Jun 18, 2018 12:54 pm    Post subject: Z19 first try and smoke/wire melted I did a mistake Reply with quote
The only OTHER wires at risk would be those
tightly bundled with the damaged wire. Even
so, the 'damage' may be limited to staining
of the insulation. If there are no wires in close
proximity to the damaged one, then you're
home almost free.
Achille
PostPosted: Sun Jun 24, 2018 12:57 am    Post subject: Re: Z19 first try and smoke/wire melted I did a mistake Reply with quote
At the end it cost me just a few cents, one diode and 3cm of wire. I just didn't test my ignition but all the others things are working.
Thanks you bob !!! Wink
