Engine running in
richard.goode(at)russiana
PostPosted: Mon Jul 02, 2018 10:00 am    Post subject: Engine running in Reply with quote
As several eagle-eyed contributors have pointed out to me, if you remove one set of sparking plugs, of course you can't turn the engine on compressed air! A foolish error and my apologies!
However I was simply making the point that the engine should be turned through a lot before allowing it to start to circulate oil widely and build up of pressure. Of course this must be done with the sparking plugs in place.
Richard Goode Aerobatics
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
Tel: +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
PS
PostPosted: Mon Jul 02, 2018 9:41 pm    Post subject: Re: Engine running in Reply with quote
Richard,
Thanks for the reply. I knew, you knew better, no need to call you on your faux pas.
Phil
Phil
