Air Camper Elevator Piano Hinge
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List
braywood
PostPosted: Tue Jul 03, 2018 12:10 am    Post subject: Air Camper Elevator Piano Hinge Reply with quote
Hello All - I thought this would be a good place to get feedback about using piano hinges for the elevator on a long fuselage Air Camper.
I have made some formed hinges, these wide base ones I think I will use for the rudder. See attached drawing.
Since you guys are much more experienced than I, can I get some feedback about the piano hinges? I am thinking they will reduce the gap and seal it at the same time. Only a bit of work needed on the trailing edge of the horizontal stab to allow full deflection of the elevators (I think, but have not actually done it yet!).
Your learned input always welcome and enjoyed!
Mark Bowler
- The Matronics Pietenpol-List Email Forum -
http://www.matronics.com/Navigator?Pietenpol-List
95w Wide Elevator & Rudder Hinge Assembly.PDF
Wide Base Titanium rudder & elevator hinge assembly
 Filename:  95w Wide Elevator & Rudder Hinge Assembly.PDF
 Filesize:  149.92 KB
 Downloaded:  81 Time(s)
pietflyer
PostPosted: Tue Jul 03, 2018 3:39 am    Post subject: Air Camper Elevator Piano Hinge Reply with quote
Do you have any pictures?
I tried sealing the gaps on my elevators and found very little difference in
performance (unlike sealing the gaps on the ailerons, which makes a HUGE
improvement).
My only concern with piano hinges is how they would be attached. I would
not rely on wood screws to hold them in place. On my ailerons (which have
piano hinges), the hinges are attached with machine screws going through the
wood into nutplates.
Jack Phillips
Pietenpol NX899JP "Icarus Plummet"
RV-10 N142KW hopefully flying this year
speedbrake(at)sbcglobal.n
PostPosted: Tue Jul 03, 2018 4:23 am    Post subject: Air Camper Elevator Piano Hinge Reply with quote
I used the formed MS hinge, (not the standard rolled knuckle) cut to about 21/2" length. I milled a slot in the wood, (1/8") and filled the gap within the slot with thin plywood and epoxy. The assembly was drilled in place and fitted with screws and "T" nuts. These were also epoxied to prevent backing out. I did this for the elevator and rudder. My aircraft has not been flight tested and this hinge method has not been proven.
 Filesize:  152.97 KB
 Viewed:  3224 Time(s)
 Filesize:  158.23 KB
 Filesize:  114.37 KB
 Filesize:  627.21 KB
pietflyer
PostPosted: Tue Jul 03, 2018 4:46 am    Post subject: Air Camper Elevator Piano Hinge Reply with quote
Michael, when are you ever going to fly that thing?  It’s been finished for over a year now, hasn’t it?
Jack Phillips
From: owner-pietenpol-list-server(at)matronics.com [mailto:owner-pietenpol-list-server(at)matronics.com] On Behalf Of Michael Perez
Sent: Tuesday, July 3, 2018 8:23 AM
To: pietenpol-list(at)matronics.com
Subject: Re: Air Camper Elevator Piano Hinge
PostPosted: Tue Jul 03, 2018 5:11 am    Post subject: Air Camper Elevator Piano Hinge Reply with quote
Hello jack. It actually has been finished for more like 3 years. lots of hurdles along the way...just typical things that have a priority over aircraft. (yes, I said it!) Anyhoot, I am in line for a hangar this summer and should have my private in hand by end of this month. (if nothing else derails my plans...)
I am also building another aircraft...a kit this time!
pietflyer
PostPosted: Tue Jul 03, 2018 5:27 am    Post subject: Air Camper Elevator Piano Hinge Reply with quote
What are you building now?
Sent: Tuesday, July 3, 2018 9:11 AM
Dan Helsper
Yes, I too would really like to see that airplane fly.
Dan Helsper
Puryear, TN
Dan Helsper
Loensloe Airfield
Puryear, TN
braywood
PostPosted: Tue Jul 03, 2018 6:27 am    Post subject: Re: Air Camper Elevator Piano Hinge Reply with quote
[quote="pietflyer"]Do you have any pictures?
improvement).
Jack Phillips
Hello Jack - thank you for your input. I need to do up a model of the piano hinge to better explain, and to convince myself it will work! I accept that sealing the elevator gap doesn't do much, but every little bit helps!
I don't have an approved (UK) hinge, so thought the piano hinge would be the least difficult to get accepted here. Will still have to use my titanium ones for the rudder.
I would use bolts and nutplates to attach the piano hinge. With the hinge pivot point at the top of the joint, elevator down deflection will be the issue to solve.
braywood
PostPosted: Tue Jul 03, 2018 7:47 am    Post subject: Re: Air Camper Elevator Piano Hinge Reply with quote
improvement).
Jack Phillips
Hello Again Jack! - here is a sketch of the piano hinge attachment I am thinking of - there would be a wedge shaped ply piece on the trailing edge of the horizontal stab and the leading edge of the elevator. A 1/8" thick wedge will give over 20 degrees deflection of the elevator - what we are required to have here in the UK.
Elevator Piano Hinge Assembly.PDF
Trailing edge of horizontal stab, 3mm ply wedge, 1 3/4" piano hinge, ply wedge, leading edge of elevator. Bolted together with nutplates.
 Filename:  Elevator Piano Hinge Assembly.PDF
 Filesize:  925.68 KB
 Downloaded:  85 Time(s)
braywood
PostPosted: Tue Jul 03, 2018 7:49 am    Post subject: Re: Air Camper Elevator Piano Hinge Reply with quote
That's not a workshop, that is a museum!! Wow.......
pietflyer
PostPosted: Tue Jul 03, 2018 8:53 am    Post subject: Air Camper Elevator Piano Hinge Reply with quote
Should work just fine
taildrags
PostPosted: Tue Jul 03, 2018 7:02 pm    Post subject: Re: Air Camper Elevator Piano Hinge Reply with quote
Braywood: if you think Speedbrake's shop is ultra-sanitary, you should see Jake Schultz's shop! Truly white-glove spotless! Jake is building a Rotec R2800 radial engine powered, steel-tube fuselage Air Camper up in Washington state.
Oscar Zuniga
Medford, OR
Air Camper NX41CC "Scout"
A75 power, 72x36 Culver prop
braywood
PostPosted: Wed Jul 04, 2018 2:19 am    Post subject: Re: Air Camper Elevator Piano Hinge Reply with quote
[quote="pietflyer"]Should work just fine
Hi Pietflyer - I got an email reply from another enthusiast and he suggested that if the horizontal stab were to flex, the piano hinge could bind and cause control problems. This was enough of a possibility, which I had not thought of, for me to stick with the individual hinges.
He also suggested that there was little noticeable benefit to having the elevator gap sealed.
Back to making my titanium hinges! Thanks for your input.
pietflyer
PostPosted: Wed Jul 04, 2018 3:41 am    Post subject: Air Camper Elevator Piano Hinge Reply with quote
If concerned about that, you could break the piano hinges into several short
sections (I did this on my aileron hinges, for the same reason). From
observing my tail section in flight (one of the great advantages of open
cockpit flying), I don't think there is enough flexure to cause any concern.
Jack Phillips
Pietenpol Air Camper NX899JP "Icarus Plummet"
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List All times are GMT - 8 Hours
