Yakjumper
Posted: Fri Jul 06, 2018 12:04 am Post subject: External Tanks - how to wire them |
Hi,
got a Yak 52 which has external tanks, but they were not used by the previous owner. Pumps and cables were removed and not installed again after the plane was shipped in a container.
So I got a new cable set and switch box from the avionics shop, pumps and parts.
But there is no fuel level sensor/switch in the external tanks. My other 52 has a fuel level sensor and the light shows red/green. So I know when the tank is empty.
Is there a way to use a fuel pressure switch (6psi), or a fuel flow sensor in line instead ? Or must it be a level switch/float in the tank ? That would not be that easy to install.
thx
Posted: Fri Jul 06, 2018 5:24 am Post subject: External Tanks - how to wire them |
You can install one of these off of a T fitting on the output of the pump. Wire it so it shuts the pump off when fuel pressure is lost.
https://www.jegs.com/i/JEGS/555/11206/10002/-1?CAWELAID=1710870554&CAGPSPN=pla&CAAGID=39714413703&CATCI=pla-457013475083&CATARGETID=230006180040357466&cadevice=c&jegspromo=nonbrand&gclid=EAIaIQobChMIt9C3o8aK3AIVUSWBCh3xWwaXEAQYAiABEgK0KfD_BwE
Dennis
To: yak-list(at)matronics.com
Sent: Friday, July 6, 2018 4:07 AM
Subject: External Tanks - how to wire them
--> Yak-List message posted by: "Yakjumper" <tobias(at)macnews.de (tobias(at)macnews.de)>
Hi,
thx
http://forums.matronics.com/viewtopic.php?p=481434#481434
http://www.matronics.com/Navigato - MATRONICS WEB FORUMS -
http://forums.msp; - NEW MATRONICS LIST WIKI -
http://wiki.matronics.com
http://www.matronics.com/cont========================
