Play in monowheel Tailwheel arm rear mounting hole.
JonSmith
PostPosted: Thu Jul 19, 2018 10:56 am    Post subject: Play in monowheel Tailwheel arm rear mounting hole. Reply with quote
A mate of mine, also with a Classic monowheel has had a problem come to light. The Tailwheel arm, where it passes through the fin’s rear close out has become disbonded from the hole and a fair bit of play in the arm has developed in an up and down sense. Only noticeable when the rear fuselage is supported with the tail wheel off the ground. The front mounting bolt and structure is fine.
We wondered if anyone has or knows of a suitable U.K. LAA approved repair scheme to rectify this oversized/ elongated hole?
Cheers, Jon
G-TERN
Classic Mono
spcialeffects
PostPosted: Thu Jul 19, 2018 12:26 pm    Post subject: Re: Play in monowheel Tailwheel arm rear mounting hole. Reply with quote
Can’t you remove the arm, 1 bolt, clean the redux off, prep the tail wheel bar area for rebonding and refit then there is no real repair as your installing it again as per the manual.
Frank Xuereb kit#165 classic monowheel
JonSmith
PostPosted: Thu Jul 19, 2018 10:18 pm    Post subject: Re: Play in monowheel Tailwheel arm rear mounting hole. Reply with quote
Hi Frank, that was my thought exactly - keep it simple!
Cheers, Jon Very Happy
G-TERN
Classic Mono
