		John Wighton
				 Posted: Wed Jul 18, 2018 3:12 am    Post subject: Varley Li-16 or Li-5 |
				Requesting user-experiences for the Varley Lithium FE batteries.
 For fitment in a Europa with 912 ULS which currently uses a Varley Red Top 25 (cranks at 310A, weighs 7.0kg).
 As l understand it the standard Ducati supply voltage of 13.5(+/-) is acceptable as the battery nominal voltage is 12.8v.
 If anybody is using one of these l would appreciate feedback.
 The Li-16 has a massive cranking current of 670A and weighs 3.2kg.  It fits the existing battery box.
 The Li-5 cranks at 335A and weights only 1.1kg.
 Many thanks for any info.
 JW
  _________________ John Wighton
Europa XS trigear G-IPOD |
		John Wighton
				 Posted: Fri Jul 20, 2018 1:19 am    Post subject: Re: Varley Li-16 or Li-5 |
				Well l wasn't exactly inundated with replies to this request.  Thanks to Richard for the related PM.
 Feedback from Varley (DMS Technologies) is that the Li-16 will provide a better solution as the Red Top 25 CA is 310A and CCA drops to 230A.  The Li-5 (along with similar low AHr capacity batteries has a CCA of effectively zero.  Meaning that ops in very cold conditions will be worse than l currently experience.
 As the Li-16 has an [effective] CA of 670A this should overcome my kickback issues in colder months.  It saves around 3.8kg and will need a lengthened battery box as it measures 203 x 78 x 139 (compared RT 25 at 181 x 77 x 167).
 Just need to start saving as it's RRP is £678 (yes, there are no decimal points in that number).
 The LAA mod process and approved list for Lithium based batteries is here:
 https://www.lightaircraftassociation.co.uk/engineering/Standard%20Mods/SM14337%20Lithium%20batteries.pdf
		Burrilla
				 Posted: Fri Jul 20, 2018 7:00 am    Post subject: Varley Li-16 or Li-5 |
				Sorry didn’t get to reply as now in Oshkosh and was travelling.
 I’ve just fitted a Li-16 for weight saving, not flown yet as I then disappeared of on holiday. Fitted the higher capacity one so if I have regulator fail I have about 2 hours of battery life with all things running.
 Dimensions slightly longer than the Varley so had to remake brackets but that was easy.
 Starts engine, 912ULS, no problems and I had. Varley 25 previously. Initial engine runs suggest everything ok and charging.
 Alan
 Sent from my iPad
  	  | Quote: | 	 		   On 20 Jul 2018, at 04:19, John Wighton <john(at)wighton.net> wrote:
  John Wighton
  http://forums.matronics.com/viewtopic.php?p=481766#481766
		h&jeuropa
				 Posted: Sat Jul 21, 2018 3:35 am    Post subject: Re: Varley Li-16 or Li-5 |
				John,
 I see EarthX is on the approved list.  They sell over here for about 400 USD, which is about 300 gbp.
 I did an article in Europa Flyer a few years ago when we installed EarthX.  We've since upgraded to the newer version with the fault circuit.  We also have added a diode to the C wire to force the voltage to 14 volts that EarthX requires to fully charge the battery.
 Jim & Heather
		Burrilla
				 Posted: Sat Jul 21, 2018 8:11 am    Post subject: Varley Li-16 or Li-5 |
				I couldn’t find a supplier in the UK of the Earth X variants.
 Although listed in Aircraft Spruce EU and LAS it’s considèred a hazardous product and therefore either won’t ship or horrendous shipping cost more than doubling the purchase price.
 Alan
  	  | Quote: | 	 		   On 21 Jul 2018, at 06:35, h&jeuropa <butcher43(at)att.net> wrote:
  John,
  Jim & Heather
  http://forums.matronics.com/viewtopic.php?p=481783#481783
		churchy
				 Posted: Sat Jul 21, 2018 9:03 am    Post subject: Varley Li-16 or Li-5 |
				Hi Alan and all
 I contacted EarthX a while back and they put me in touch with CFS Aero who have current stock in UK.
 Richard
 G-RPCC Motor Glider taking shape...
  	  | Quote: | 	 		   On 21 Jul 2018, at 17:10, Alan Burrill <alanb(at)dpy01.co.uk> wrote:
  Alan
 > John,
 > Jim & Heather
		dpark748(at)me.com Guest
				 Posted: Sat Jul 21, 2018 9:16 am    Post subject: Varley Li-16 or Li-5 |
				Bought my EarthX off CFS and i think Metal Seaguls sells them
 Dave Park
  	  | Quote: | 	 		   On 21 Jul 2018, at 18:02, Sky <richard.churchill-coleman(at)sky.com> wrote:
  Hi Alan and all
  Richard
 > Alan
 > Sent from my iPhone
 >> John,
 >> Jim & Heather
