Wing leveller
william(at)wbliss.co.uk
PostPosted: Sat Jul 21, 2018 1:11 pm    Post subject: Wing leveller Reply with quote
Hello all
Can anyone advise on the current market/tech in wing levellers for
Permit Europa's in UK. My instruments are mainly "steam type" and I do
not want to change them all. I may add a pitch controller in the future.
I have found Trio, Trutrac, Dynon and Garmin. Don't need a big bright
display duplicating what I can already see and hoping not to spend a
fortune. Are the older Navaid units reliable?
William Bliss G-WUFF Mono
dpark748(at)me.com
PostPosted: Sat Jul 21, 2018 1:20 pm    Post subject: Wing leveller Reply with quote
I fitted Trio Autopilot and Alt. Hold. Both fit under seats and work perfectly, linked to GPS.
Dave Park
On 21 Jul 2018, at 22:11, William Bliss <william(at)wbliss.co.uk> wrote:
Hello all
Can anyone advise on the current market/tech in wing levellers for Permit Europa's in UK. My instruments are mainly "steam type" and I do not want to change them all. I may add a pitch controller in the future. I have found Trio, Trutrac, Dynon and Garmin. Don't need a big bright display duplicating what I can already see and hoping not to spend a fortune. Are the older Navaid units reliable?
ken carp
PostPosted: Sat Jul 21, 2018 1:26 pm    Post subject: Wing leveller Reply with quote
Still using a Trutrak for ten years ,600 hours and it works without problem.
Sent from my iPad
Ken Carpenter
On Jul 21, 2018, at 5:11 PM, William Bliss <william(at)wbliss.co.uk> wrote:
Hello all
ken carpenter
Ivor
PostPosted: Sun Jul 22, 2018 7:57 am    Post subject: Re: Wing leveller Reply with quote
Ditto with a Trutrak still working well after 10 years, great for long distance touring allows frequencies changes and complex navigation to be undertaken
without being 20% off track when you look up again,
Duncan McFadyean
PostPosted: Sun Jul 22, 2018 11:44 am    Post subject: Wing leveller Reply with quote
Had a lot of difficulty with (earlier, Digitrak) Trutrak. Mostly I think due to overheating of the voltage regulator in the servo, which then caused thermal shut down until it cooled down, but without any indication this was happening other than finding oneself pointing in the wrong direction. New servo circuit board(s) and, in particular, a cooler environment seems to have solved that for 10+ years now. A similar effect occurs when the shear-screw shears, but without knowing it; it's not immediately apparent.
Note that Trutrak's servo is widely used by other brands.
Duncan McF.
----Original Message----
Date: 21/07/2018 22:11
Subj: Wing leveller
--> Europa-List message posted by: William Bliss <william(at)wbliss.co.uk>
Hello all
fortune. Are the older Navaid units - MATRONICS WEB FORUMS -
graeme bird
PostPosted: Tue Jul 24, 2018 7:04 am    Post subject: Re: Wing leveller Reply with quote
I put in a trutrak ADI pitch and roll slaved to my area 500 and am very pleased with it. Needed a step up in the roll servo from the baseline.
Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk
roddyeuropa(at)aol.com
PostPosted: Tue Jul 24, 2018 9:47 pm    Post subject: Wing leveller Reply with quote
I fitted a trio with both roll and pitch. All works well, but if I did it again I probably wouldn't install the pitch servo. It a lot more work to install (pitch tube needs to come out) and I don’t use it that much.
Roddy Kesterton
G-IKRK
PostPosted: Thu Jul 26, 2018 10:18 pm    Post subject: Wing leveller Reply with quote
Thank you everyone for your replies regarding a wing leveller.
I will see what I can find at the next LAA rally.
Andy Draper is presently testing an aircaft with the Garmin G5 setup.
William
