Baffle Tension Rod - Outboard
LarryRosen
PostPosted: Wed Aug 01, 2018 5:35 pm    Post subject: Baffle Tension Rod - Outboard Reply with quote
Does the outboard baffle tension rod go below the oil return lines (tubing) or between the engine and the oil return lines?
Larry
Still Building
Larry Rosen
#40356
N205EN (reserved)
<http>
jesse(at)saintaviation.co
PostPosted: Wed Aug 01, 2018 5:49 pm    Post subject: Baffle Tension Rod - Outboard Reply with quote
I think the intention is for it to go under the oil lines, but if you can get it between the oil lines and the engine without the possibility of chaffing either, then I think you’re fine.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
jesse(at)saintaviation.com
Larry
Still Building
Larry Rosen
#40356
N205EN (reserved)
&lt;http&gt;
http://forums.matronics.com/viewtopic.php?p=482005#482005
LarryRosen
PostPosted: Wed Aug 01, 2018 6:02 pm    Post subject: Baffle Tension Rod - Outboard Reply with quote
I am struggling to get it to work either way lol.
Sent from my mobile phone
Sent: Wednesday, August 1, 2018 9:52 PM
Subject: Re: Baffle Tension Rod - Outboard
--> RV10-List message posted by: Jesse Saint <jesse(at)saintaviation.com>
Jesse Saint
352-427-0285
> --> RV10-List message posted by: "LarryRosen" <N205EN(at)gmail.com>
> Larry
> Still Building
> Larry Rosen
> #40356
> N205EN (reserved)
> &lt;http&gt;
Larry Rosen
#40356
N205EN (reserved)
<http>
Kellym
PostPosted: Wed Aug 01, 2018 6:11 pm    Post subject: Baffle Tension Rod - Outboard Reply with quote
Keep in mind that there are necessary bends in the rods. BTW, if you
have trouble threading the supplied rod, #6 threads-all rod works
equally as well, providing you place some heat shrink or rubber tubing
over the threads in areas that could rub oil tubes.
*Sent:* Wednesday, August 1, 2018 9:52 PM
*To:* rv10-list(at)matronics.com
*Subject:* Re: Baffle Tension Rod - Outboard
Jesse Saint
352-427-0285
> Larry
> Still Building
> Larry Rosen
> #40356
> N205EN (reserved)
> &lt;http&gt;
Kelly McMullen
KCHD
