Europa-List: Re: Water pump removal « inaircraft » XS
kheindl(at)msn.com
PostPosted: Tue Aug 07, 2018 5:22 am    Post subject: Europa-List: Re: Water pump removal « inaircraft » XS Reply with quote
To find a leak why not use the same technique that is used to find one in your car engine , where you put an additive into your coolant and then use an ultraviolet light after running the engine ?
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> on behalf of tennant <barrington.tennant(at)gmail.com>
Sent: 07 August 2018 12:47
Subject: Re: Water pump removal « inaircraft » XS
--> Europa-List message posted by: "tennant" <barrington.tennant(at)gmail.com>
Hi John,
There is a drain hole under the water pump which is designed to allow water to exit that has passed the water pump seal, so that it does not enter the crankcase through the oil seal.
The Manual Shows an engine Strip down to Change the seal but I have done it in situe from under the plane. A fiddle, but possible.
Mine is a 912 on a Classic mono so your Access could be different.
Best of luck
Barry
Barry Tennant
D-EHBT
At EDLM - Germany
http://forums.matronics.com/viewtopic.php?p=482142#482142
st Email Forum -
pa-List" id="LPlnk872752" class="OWAAutoLink" previewremoved="true"> http://www.matronics.com/Navigator?Europa-List
p; - MATRONICS WEB FORUMS -
k304638" class="OWAAutoLink" previewremoved="true"> http://forums.matronics.com
70175" class="OWAAutoLink" previewremoved="true"> http://wiki.matronics.com
p;   -Matt Dralle, List Admin.
id="LPlnk461192" class="OWAAutoLink" previewremoved="true"> http://www.matronics.com/contribution
