Wing pip pin required
Europa48
PostPosted: Tue Sep 04, 2018 11:04 am    Post subject: Wing pip pin required Reply with quote
Somehow during transporting my Europa XS to have a new permit done I have managed to lose a wing pip pin.
Does anyone have a spare they can sell me or advise where I can obtain one?
David
rlborger(at)mac.com
PostPosted: Tue Sep 04, 2018 3:42 pm    Post subject: Wing pip pin required Reply with quote
David,
I assume you mean the small pip pin for the tie bar socket and not the big pip pin that passes through the spar. I believe one should be available from Europa for about £45.
If you can not source the small pip pin on your side of the pond, I have an extra I can pass across to you for cost ($44) plus shipping (?). Probably end up about the same cost as one from Europa.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop (130 hrs).
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP, Hercules Prop.
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
David
Europa48
PostPosted: Wed Sep 05, 2018 10:45 am    Post subject: Re: Wing pip pin required Reply with quote
Managed to buy one locally today from a fellow Europa pilot.
