KLX-135 and KLX-135A display replacement
vanremog(at)aol.com
PostPosted: Wed Sep 05, 2018 6:40 pm    Post subject: KLX-135 and KLX-135A display replacement Reply with quote
For those of you needing this service, the contact info is below.
Model
Part Number
Average Test
Average Estimated Repair
Average Lead Time
KLX-135A or 135
$440.00
$970.00*
5 days for evaluation; 10-12 days for repair upon approval
*Repair is subject to availability of parts due to age/condition of unit.
Repairs, Alignments, and Overhauls are quoted on a time and Material basis after bench check findings. Evaluation Fees will apply if repair is declined.
Average Repair prices indicated are historical averages and should be used for reference only. An actual cost to repair or overhaul an item can only be determined by proper bench testing. In most cases, the following factors will affect the cost to repair or overhaul an item:
- Age of Unit
- Service Bulletin Status
- Operation Environment (climate, humidity, vibration, etc.)
Southeast Aerospace
Orlando-Melbourne International Airport
Attn: Repair Shop
1399 General Aviation Drive
Melbourne, Florida 32935
USA
Laurie Burgess | Southeast Aerospace | Shop Administrator | E: laurie.burgess(at)seaerospace.com (laurie.burgess(at)seaerospace.com)
T: 321.255.9877 Ext. 266 | F: 321.255.1438 | www.SEAerospace.com
