genie(at)swissmail.org Guest
Posted: Sun Sep 09, 2018 8:20 am Post subject: Safe Seats |
As I possess and Avid Flyer and it is similar to a Kitfox I make use of
this list. At present the seats of my Avid Flyer are out in order to
facilitate the installation of underseat avionics and an antenna. Does
anyone know how to improve the crash survivability of my aircraft by
either replacing or modifying or including any additions to the seats.
In my opinion it is necessary to have good seats to survive any crash
unscathed or with minimal injuries. Thank you.
George Nielsen
Avid Flyer I-6640
The Hague, the Netherlands
michaelgibbs(at)cox.net Guest
Posted: Sun Sep 09, 2018 1:33 pm Post subject: Safe Seats |
Hi George,
As the old timers on this list are aware, I crashed a model IV Kitfox in
August of 2004. Based on my experience, it's not the seats that you
should be focused on, it's the instrument panel and lap/shoulder
restraints. In my case the airplane impacted rough terrain nose first
which collapsed the nosewheel and caused the fuselage to snap at the
firewall. When the firewall-forward portion bent upwards relative to the
rest of the airframe, it caused the instrument panel to move closer to
myself and my passenger and the bottom of the panel smashed me in the
shins, breaking both of my legs below the knee.
My passenger suffered a non-displaced fracture of a lumbar vertebrae but
I think that was simply because there isn't much space or structure
under the seats to absorb impact. He recovered fully with bed rest.
I think the shoulder straps and lap belt did what they were supposed to
do in terms of restraining us but since the panel moved closer and
downward I still managed to hit it hard enough to break all of the bones
in my face except for my nose (eye orbitals, cheek bones, jaw, etc.). My
face was very swollen and it was several days in the hospital before
they noticed on an x-ray that the set knob for the altimeter was
embedded in my cheek!
I am interested in those airbags that are integrated into airplane
shoulder straps, I think in my case that would have made a lot of
difference. Last I checked they were not available for Kitfox/Avid
aircraft but that was quite a while ago and it's time to check again.
Getting back to your question, though, I do know some builders have used
nylon straps to provide additional structural support to the bottom of
the seat pans due issues with cracking or failures of the fiberglass
(usually due to heavy people, not accidents). Several straps running
fore/aft can be attached to the bars in front (below the knee) and back
(beneath the occupant's bottoms) with just enough slack so that, when
installed, the bottom of the seat pan is partially supported by the straps.
I hope this was helpful.
Mike G.
Phoenix, AZ
Kitfox Series 7
George Nielsen wrote on 9/9/18 9:20 AM:
of this list. At present the seats of my Avid Flyer are out in order
to facilitate the installation of underseat avionics and an antenna.
Does anyone know how to improve the crash survivability of my aircraft
by either replacing or modifying or including any additions to the
seats. In my opinion it is necessary to have good seats to survive any
crash unscathed or with minimal injuries. Thank you.
George Nielsen
Avid Flyer I-6640
