Mounting the control stick-advice on the nut and bolts
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List
bickers.ken(at)gmail.com
PostPosted: Sun Sep 09, 2018 5:29 pm    Post subject: Mounting the control stick-advice on the nut and bolts Reply with quote
Yes, Mark!
As for the other part of your question about cotter pins, there's a simple way to think about what nuts to use.  When trying to decide what nut to use, consider motion and heat.  If the nut is attaching any part of a structure that can rotate, you will need to use a castle nut with a corresponding cotter pin.  If the structure cannot rotate, use a stop nut.  If the structure is aft of the firewall (and therefore not subject to the possibility of high temperatures), you can use a nylon stop nut.  If it forward of the firewall (and thus subject to even the possibility of high heat), use an all-metal stop nut.
One additional consideration, still relating to motion, is that if the bolt can only be stressed in sheer (and in no way will ever see tension), you can use a low profile stop nut -- again, a nylon version of the stop nut if aft of the firewall and all-metal if forward of the firewall.
Cheers, Ken
On Sun, Sep 9, 2018 at 7:04 PM, Mark Roberts <mark.rbrts1(at)gmail.com (mark.rbrts1(at)gmail.com)> wrote:
--> Pietenpol-List message posted by: "Mark Roberts" <mark.rbrts1(at)gmail.com (mark.rbrts1(at)gmail.com)>
So THAT’S what that bag of fender washer I bought are for!
Thanks Ken. Just what I needed.
Mark
http://forums.matronics.com/viewtopic.php?p=483053#483053
br> enpol-List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Pietenpol-List
WIKI -
- The Matronics Pietenpol-List Email Forum -
Mark Roberts
PostPosted: Sun Sep 09, 2018 6:08 pm    Post subject: Mounting the control stick-advice on the nut and bolts Reply with quote
Much appreciated Ken.
I need to fish out the Bingalis books from storage as I am sure my answers
are there, but that might take as long to locate as it will to build the
Piet!
That was very helpful. I do have all of the necessary hardware and have
test fit everything (without actually using the lock nuts- I didn’t want to
put them on then take them off a ruining the “locking” potentially when I
put them back on), before the project went into a 6 year hibernation.
Now, if o could just jumpstart my memory cells...
Mark
On Sun, Sep 9, 2018 at 8:31 PM Ken Bickers <bickers.ken(at)gmail.com> wrote:
[quote] Yes, Mark!
boyerjrb(at)comcast.net
PostPosted: Sun Sep 09, 2018 6:38 pm    Post subject: Mounting the control stick-advice on the nut and bolts Reply with quote
Hi Mark, Use wood washers on the bolts through the wood. They are much larger than the standard small washer used on bolts through metal. Look in the Aircraft Spruce catalog, I think they are AN-960 but check their catalog. If you use cotter keys you can put them in bolt head down, or use bolt head up and use self locking nuts or castle nuts with cotter keys. Jim B
On September 9, 2018 at 5:27 PM Mark Roberts <mark.rbrts1(at)gmail.com> wrote:
I have the appropriate Aircraft Spruce ordered AN bolts and nuts, etc.
1. What I am wondering is about the way to assemble them. Do I mount them nut side up through the floor, or bolt head inside- nut side down... I am using lock nuts, and where called out, the cotter pin style (I am going from memory as I have yet to refer back to the plans since restarting the build- but will before installing).
2. Is a washer enough to keep the lower part of the assembly from digging in and crushing the bottom of the plywood on the underneath side, or should I weld either the nuts or heads to a plate so they are tied together somehow.
I am thinking that once I put the fabric on, the heads or nuts will not be accessible without cutting and repairing the fabric, so what’s best? I don’t believe these were called out to be cotter pinned in.
I have the EAA Books, but don’t remember if this was addressed.
Thanks for the help.
Mark
http://forums.matronics.com/viewtopic.php?p=483050#483050
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Pietenpol-List All times are GMT - 8 Hours
