motoadve
Posted: Thu Oct 11, 2018 5:53 pm Post subject: What is the proper starting procedure? Housai engine. |
Tried it today and could not start it.
When the air valve was open, we had 33 of air.
After 4 attempts we ran out of air, and no flying.
What is the proper procedure to start the plane?
hkgibby(at)yahoo.com Guest
Posted: Thu Oct 11, 2018 6:11 pm Post subject: What is the proper starting procedure? Housai engine. |
Got feed it fuel with primer (right hand) as you push start button and then move left hand to throttle and work it...it should start.
Quote: | On Oct 11, 2018, at 9:53 PM, motoadve <motoadve(at)racsa.co.cr> wrote:
http://forums.matronics.com/viewtopic.php?p=483770#483770
Posted: Thu Oct 11, 2018 6:38 pm Post subject: What is the proper starting procedure? Housai engine. |
Dumb question-was the mag switch on in the rear cockpit?
Dennis
wlannon(at)shaw.ca Guest
Posted: Thu Oct 11, 2018 7:55 pm Post subject: What is the proper starting procedure? Housai engine. |
Not dumb at all. Excellent question for a newbe. Totally different than
his 172 or other type.
motoadve
Posted: Thu Oct 11, 2018 8:14 pm Post subject: Re: What is the proper starting procedure? Housai engine. |
Yes and the engine actually tried to start a couple of times.
glipaz
Posted: Fri Oct 12, 2018 6:49 am Post subject: Re: What is the proper starting procedure? Housai engine. |
If you have FaceTime I’m happy to walk you through it live. Just text me. 310-245-7078
Gil
motoadve
Posted: Fri Oct 12, 2018 7:12 am Post subject: Re: What is the proper starting procedure? Housai engine. |
glipaz wrote: | If you have FaceTime I’m happy to walk you through it live. Just text me. 310-245-7078
Gil |
Thanks Gil will do.
Flibob
Posted: Fri Oct 12, 2018 9:26 am Post subject: What is the proper starting procedure? Housai engine. |
Not getting the rear mag back on common even for experienced CJ pilots.
GiddyUp,
Bob
On Oct 11, 2018, at 11:54 PM, Walter Lannon <wlannon(at)shaw.ca> wrote:
Not dumb at all. Excellent question for a newbe. Totally different than his 172 or other type.
