mhealydds
Posted: Sat Oct 06, 2018 9:28 am Post subject: Magneto gasket |
After adjusting timing (off 3 degrees) and doing a leak check after second annual condition inspection I have an oil leak under right mag on stock IO-540 engine. I assume that means I need new gasket. I see two part numbers. Which gasket do I need?
Matt
Kelly McMullen
Posted: Sat Oct 06, 2018 3:45 pm Post subject: Magneto gasket |
For the C4B5 and D4A5 I only see one gasket for the mag and adapter: 62224.
What other part number do you see? Do you have an engine other than the most common 250/260hp IO-540?
| Quote: | | Sent from my IBM-360 main frame |
On Sat, Oct 6, 2018 at 10:33 AM mhealydds <mhealydds(at)gmail.com (mhealydds(at)gmail.com)> wrote:
| Quote: | --> RV10-List message posted by: "mhealydds" <mhealydds(at)gmail.com (mhealydds(at)gmail.com)>
Matt
http://forums.matronics.com/viewtopic.php?p=483645#483645
FORUMS -
WIKI -
b Site -
-Matt Dralle, List Admin.
A&P/IA, EAA Tech Counselor
KCHD |
