r.vogel(at)ggs.ch Guest
Posted: Sat Oct 20, 2018 11:39 pm Post subject: Old / new tailwheel |
Hello everybody
My Europa Classic, finished one year ago, has still the original tailwheel.
After 30 hours test flights I am thinking about replacing the “old”
tailwheel with the XS type.
But I cant find any problems with steering for example. My question to
somebody with experience
on both types of wheels: "Is it worth the great effort for this
modification?"
But there is an other problem with big bouncing on uneven grass runways.
A very strong rebound
is resulting in strong bouncing with force me for a go around mostly.
There is the red rubber block and old shock absorber. Does somebody have
got any
experience and a solution about this problem.
I think this is not in connection with the classic tail wheel?
Regards, Ruedi Vogel, HB-YJF
JonathanMilbank
Joined: 14 Apr 2012 Posts: 384 Location: Aberdeen area
Posted: Sun Oct 21, 2018 4:14 am Post subject: Re: Old / new tailwheel |
Hello Ruedi,
My experience of Europa tail wheels is many hundreds of hours with the original type and about 25 - 30 with the XS type. My preference is for the original connected directly to the rudder pedals with no springy links, so there is immediate response to any movement of the pedals. I didn't enjoy the slight lag/delay in directional control when flying a friend's Europa with the XS tail wheel, because it made me feel insecure and less in control. But perhaps if I had continued with his XS for many more hours, then eventually I would have gained confidence with it.
My Classic Europa had the red block shock absorber with hydraulic dampers and seemed to work well without much bouncing, if I made sure to land it with both main wheel and tail wheel contacting the ground at the same time. In fact I would try to have the stick completely rearwards at the moment of landing and maybe the tail wheel touched the ground first. But if the main wheel touched the ground first, then there was usually a bounce. This bounce almost never forced me to go around.
tennant
Posted: Mon Oct 22, 2018 4:07 am Post subject: Re: Old / new tailwheel |
Hi Ruedi,
Get rid of the old tail wheel. I did about 100 hrs on it and was scared of it. The later wheel is much better. I find the spring action perfect on take off as there is nearly no transition from ground to air.
As to landing, I am told by passengers that I land with the tail wheel first, I never notice because I am concentrating on keeping it straight. If you do that there is no bounce!
If you fit the new tail wheel see recent posts about mounting it.
Barry
_________________ Barry Tennant
D-EHBT
At EDLM - Germany |
Posted: Mon Oct 22, 2018 6:47 am Post subject: Old / new tailwheel |
Hi Ruedi
One more thing, Don’t get rid of the pushrod that moves the rudder. Connecting the rudder cables directly to the rudder puts too much load on the rudder hinges
And the flange. Europa did take over my mod for this, the tailwheel is driven by cables from a bracket bolted to the bulkhead.
It is possible to use the existing crank driving the old Classic tailwheel but using the mod will save weight.
Graham
Quote: | On 22 Oct 2018, at 13:07, tennant <barrington.tennant(at)gmail.com> wrote:
Hi Ruedi,
Barry
Barry Tennant
D-EHBT
At EDLM - Germany
http://forums.matronics.com/viewtopic.php?p=483925#483925
Posted: Sun Oct 28, 2018 9:10 am Post subject: Old / new tailwheel |
Hi
Many thanks to Graham, Barry, Jonathan and Andreas for the good advises! Now I have decided to rid the old tail wheel. I will keep the old
wheel bearing block with a modified steering arm. That's the way I can use
the push road and the cables without modification. Is a bit heavier as the
solution according to Mode 77. But I have had 3.7kg lead in the back as W/B
compensation before.
Best regards
Ruedi Vogel, HB-YJF
Am 22.10.2018 um 16:41 schrieb Gaham Singleton:
Quote: | Quote: | --> Europa-List message posted by: Gaham Singleton <grahamsingleton(at)btinternet.com> (grahamsingleton(at)btinternet.com)
Hi Ruedi
Graham
Quote: | On 22 Oct 2018, at 13:07, tennant <barrington.tennant(at)gmail.com> (barrington.tennant(at)gmail.com) wrote:
--> Europa-List message posted by: "tennant" <barrington.tennant(at)gmail.com> (barrington.tennant(at)gmail.com)
Hi Ruedi,
Barry
Barry Tennant
D-EHBT
At EDLM - Germany
Ruedi Vogel
Wiesenweg 6
CH-3380 Wangen a.A.
Posted: Mon Oct 29, 2018 12:11 am Post subject: Old / new tailwheel |
I did it that way first. Worked well. You might need a wider crank on the new tail wheel. As you slow down through 20 knots you lose rudder control, no prop draft, so tail wheel steering has to take over.
On 28 Oct 2018, at 17:00, Ruedi Vogel <r.vogel(at)ggs.ch (r.vogel(at)ggs.ch)> wrote:
Quote: |
Hi
Best regards
Ruedi Vogel, HB-YJF
Hi Ruedi
Graham
Hi Ruedi,
Barry
Barry Tennant
D-EHBT
At EDLM - Germany
Ruedi Vogel
Wiesenweg 6
CH-3380 Wangen a.A.
